Label that will toggle LABELCODE possible ?
  • Label that will toggle LABELCODE possible ?
    Is it possible to have a label that will switch labelcode every X seconds or so... I had a look at the TMR and IDL events but they do not seem to do the trick.
    Example: A Label that will toggle between DATE and TIME every 5 seconds...
    In the .skin file:
    (First Label in .skin file)
    L01,xxx,...,xxx,"DATE>>TIME",""
    TMR,5
    In ExecTBL:
    "TIMER","SWITCHLABEL;1",myscreen.skin
    Ride Runner RR's Myspace
      I can only get this to switch once, when i enter the screen...
      I even tried "TIMER","SWITCHLABEL;1||MAIN",menu.skin in ExecTBL (this is in the MAIN screen) but the MAIN command does not seem to reset the timer....
      Any ideas ?
        sorry, I meant to improve the timer command to re-occur every so often but forgot to do it.. the latest test version (just posted it), should have that improvement. Look for the link in the release thread.
          Thank you Guino, exactly what I was looking for !!!
          Will try this as soon as i get home...
            This is working great now.
            Thanks again, Guino!
              Hey Guino,
              I'm blind?!
              But where can I find this "test version" ?
              Greetings,
              Winni
                here's the "Test" Version
                http://www.rrdownloads.net/beta/beta.htm
                  @Gixxer: THANKS!!
                  EDIT: Works without problems here! (nice place saving feature )
                  EDIT2: Found a bug (perhaps). The internal DVD player does not playing anymore.
                  Switched back to 02.05. Release. Everything perfect with dvd playling...
