MC 2.0 SKin Mod
  • MC 2.0 SKin Mod
    Here is my mod to CDR SKulls MC 2.0 skin
    I loved the skin but wanted a little more from it.
    Well here is a screen shot of the main menu with the IGMON iguidance mod.
    Also utilizes the LostReceptions GPS Gasoline Pluggin
    This is on my home computer so no GPS info displaying but it will.
    Anyway with out further adoo...
    Download and install at your own risk (disclaimer) nothing should happen
    All ways make a back
    Installation instructions included in zip file
    Jaguar back ground not included and will not change your current back ground
    REQUIREMENTS
    (1) IGMON 2.0 or higher - Link Here
    (2) CDR Skulls MC 2.0 Skin - Link Here
    (3) Lostreceptions GPS Gasoline (optional) - Link Here
    (4) Iguidance 2.1.1 or higher (for use with IGMON and the Next Turn Label)
    (5) MC 2.0 Skin Upgrade pack (this thing your reading about) - Download Below
    UPDATE: June 18 2006
    (1) Added instructions on updating
    and installtion GPS Gas to work with this
    (2) Added my menu.txt file to update your buttons
    UPDATE: June 06 2006
    Bugs Fixed
    (1) Next Turn does not allways display on main menu - May or May not work well (this is an IGMON issue)
    (2) If you get above the double digits on the Speedo, it doesnt display the speed.
    CHANGES: June 06 2006
    (1) Scrolling Next Turn Label
    (2) Track Title scrolling next to Next Turn
    (3) Moved Sattelite label from left to right
    (4) Font Size much bigger for next turn and track title
    (5) Volume and Date Label - Changed fonts and locations for better fit
    This has been updated to accommodate IGMON 2.0.
    (6) Updated GPS screen to match main menu lay out
    Here is the jaguar back ground if you need (or want) it.
      The next turn label does not allways work well. This is dependent on IGMON and igmon is still pretty buggy with this feature. If you would like to remove it, Feel free.
        I downloaded upgrade copied everything to mc2.0 skin folder and didn't see a change in skin.
          Make sure you are replacing the skin files as well. Most of the change is with the skin files. Also only changes the navigation screen and the main screen.
          To change the text on the buttons you have to edit menu.txt your self. I did not include this edit in my mode since everyone has a different set of commands they want on there main menu.
          Otherwise if you think you have doen this. Double check becuase you should definitely see the change.
            Network Status
            Hi, I am trying your skin mod. What is the network status? and where does it pull the info from? Thanks!
              Network status is suposely to detect if you are connect to the internet (but doesn't work well due that you can be connect to a AP that doesn't have intenet) you better of with the app from b8bboi call "Autonetdetect".
              Thanatos.
              RexBruMet Skin for FrodoPlayer
              Nissan Aux-in MOD
              Originally posted by bgoodman
              We're an international forum, post in whatever langauge you like.
                All it does is detect a network connection. It works OK but will not detect an actual internet connection. Gets the info from road runner which monitors your network status from windows.
                It is just a simple skin command.
                  I like this, pretty cool upgrade from MC original
                  New Age Garmin - Skin for RR
