execute on down, stop or execute some else on up
  • execute on down, stop or execute some else on up
    well the tiltle says it all, i would like to know if it is possible to have rr execute or keep executing a command by holding a button and execute another or stop executing by releasing a button?
    sjors
    currently not possible direcly, but you can easily make an extension plugin for that.
    Ride Runner RR's Myspace
      i can? but how do declare the up and down possition of a button?
      btw, i've made a lpt_control plugin for rr, but it needs a dll, do you know any way to let the dll stay in the .exe dir instead of copying it to system32?
      sjors
        this depends on how you load the DLL and which type of DLL it is. In most cases, it should work from RR's dir too.
        It's a bit complicated to do it if you want the same button to produce down and up events, it's easier if you make it by press to go on, then press to stop.. there are multiple ways of doing that. But it's not a bad idea to add such function (command on DOWN and another command on UP).
          yep that should be awsome. your way of pressing twice i've already used by making a swichbutton command
