Advanced Browse.rrl question
  • Advanced Browse.rrl question
    Well it maybe isn't advanced but it doesn't seem to be in the forum anywhere so I thought I would ask.
    The problem I am having is. I am using browse.rrl to display virtual folders from my music. My setup is this. My browse file is located in c:\rrbrowse (which obviously my music folder in rr.ini points to). The browse entries point to specific folders in c:\media\. Problem is if I click on say albums in browse it takes me to c:\media\playlists which holds sub folders for each letter of the alphabet. The problem is once here I am able to back out to the root.
    So my question is is there anyway to stop this bearing in mind I need the back feature but from the c:\media\playlists folder it needs to back to c:\rrbrowse not c:\media? pathlimit=true doesn't work.
    Woops, Sorry just realised I put this in completely the wrong section. Can an Admin please move?
      Hey Cruizer, there is an option in rr.ini that does this, try setting
      M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
      DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
        As I understand it, RR doesnt allow this to happen. Going back will simply take you up a folder level, not back to the folder the RRL file is placed in. And I think the pathlimit will only work if you are within the path set in the config. It will need to be programmed into RR to detect when a browse.rrl is used and somehow remember the path.
        I too would like to see this feature added
        Jarrod - Holden VX S!
          You could just place another Browse.rrl file in C:\media\playlists and have it point to c:\rrbrowse
