The W3bMa5t3r's New Cobra Skin - Darker...
  • The W3bMa5t3r's New Cobra Skin - Darker...
    Ok, well I decided to get off my blue brushed metal kick and go a bit darker with my newest revision/rebuild of my skin. Officially I guess this is CobraSkin_08... I'm not really creating this for the masses, but as with my last skins that had a few hundred downloads, I figured I'll release what I've done/am doing and you can take it from there if you so choose.
    DOWNLOAD THE SKIN: -HERE- Currently 10.7 MB
    NOTE: This skin is not yet complete, so the download isn't either, but I'm posting what I have so far, and the download will be updated with each new skin as completed. Also, this archive contains MY root Road Runner folder and setting, so don't just extract the full file into your Road Runner directory. I've done this because I'm including SonicXtacy02's TrafficCam program, lostreception's GPSGAS plugin, the Web Browser plugin, Prefect's 1ClickWebCamRecord,
    and more with my skin. This way the functionality will remain without needing to make too many changes. Check out my "RR.INI" and "ExecTBL.ini" files to see what you need to add to yours. Copy the GPSGAS and LiveTraffic folders to your Road Runner folder.
    If you get a "file not found" when trying to download it's probably because I'm uploading a new and updated version of the skin/archive.
    This skin is still in progress and I'll update as I complete the skins. Once I'm finished, or at least mostly there, I'll release the PSDs.
    PSDs - Download
    MAIN MENU
    - (Cobraskin 08 - MAIN MENU PSDs (ON-OFF). This includes the ON and OFF PSDs for the MAIN MENU only. I'll release ALL PSDs once completed.)
    Skins/Menus Completed Thus Far (and in the download archive):
    Main Menu
    GPS / iGuidance
    Audio Player
    Audio Browser
    Playlists
    PopUp Volume Control
    WEATHER
    CDRIP (updated skin)
    Traffic Cams (by SonicXtacy02)
    PicViewer
    GPS Gas (by lostreception)(if you've never had this before, it's best to download/run his install program so that the required ocx/dll files are registered with your system)
    Video Player & Browser
    DVD Player (using VLC media player - controls of skin mapped to hotkeys of player)
    1ClickWebCamRecord (by Prefect)
    Web Browser Plugin
    To Come:
    Extended Weather Detail
    Skin Browser
    WinTV and FM
    Vehicle Maint??
    If there is something you'd like me to add to this, let me know.
    SCREENSHOTS:
    More Screenshots
      More Screenshots
        Reserved For Screenshots
          Would work nicely with my Mustang
          One comment: The blue text in the Weather screen is very hard to read. You should use a lighter text on a gray background. The green you used on the same screen worked nice.
            I thought that was a bit hard to see. Updated.
              Added PicViewer & TrafficCams (by SonicXtacy02)
                Added GPSGAS (by lostreception)
                  excellent
                  from a vet and fellow virginian nice skin. how about vehicle maint? Keep up the good work
                    THANKS!
                    Is there a particular program or plugin you're using, or would you just like the menu item added with it's own screen/skin to embed it?
                      Added Video Player and Browser... DVD Player is next and then back to working on Web Plugin.
                        DVD Player Added
                          Originally posted by W3bMa5t3r View Post
                          THANKS!
                          Sorry about that i'm using a program called Automotive wolf has a tone of stuff on it. http://www.lonewolf-software.com/ (free trial)
                            To add the Automotive Wolf software, add this code to the MENU2.skin file:
                            Code:
                            /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
                            L,290,367,205,31,255,255,255,24,"SF TransRobotics","=CAR MAINT","CENTER"
                            /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                            B,285,343,221,81,"RUN;C:\PROGRAM FILES\AUTOMOTIVE WOLF\AUTOMOTIVEWOLF.EXE;AUTOMOTIVE WOLF",
                            This should work. Make sure the program location is correct with your installation. This will create a button on the applications page. When you click the Car Maint button it should load and embed your program. Let me know how it turns out.
