Freedom icons and logo not showing
  • Freedom icons and logo not showing
    I've searched through the 30 odd pages of forums and can't seem to find this so maybe someone can help.
    I've got the latest RR and Freedom skin loaded.
    It's in C:\Program Files\Road Runner\Skins
    The problem I'm have is that the icons and the logo are not showing.
    I've turned on icons in RR Config and nothing.
    Other skins seem to work as long as the files are not in a subfolder.
    Although if I move the png files to the same directory as the skin and change the path in menu.txt, it still doesn't show.
    Is it the file format png or something else?
    Any ideas?
    VoomPC, VIA C7 1.5 Ghz, 7" Newision LCD, 80 Gig WD 5400 RPM Laptop Drive, M2-ATX, RoadRunner, iGuidance, Freedom 2.0, AT&T Natural Voice Hot Babe Audrey. All wrapped up in a piece of crap Suzuki Grand Vitara.
    you need to install flash 9, that will sort this out :-)
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
      Thanks, that explains it....
        Unfortunately that didn't work. Any other thoughts?
          Did you install flash under internet explorer?
          7" TouchScreen Carputer
          Rockford Fosgate 1501BD and Rockford 551s
          12" MTX 9500 in a SS* or a 12" Brahma in a SS*
          ZAPCO COMPONENTS in front and RFs in rear
          2 YellowTops and a 200amp Iraggi Alternator
          *Snell Shell box from nolteaudio.com
            Well, that's interesting. I was using firefox so I changed to explorer and installed again.
            Now it just sits on the Road Runner launch screen.
              Are you using freedom v1 or v2 beta? Version 1 dosen't work with flash 9, but don't worry I think v2 will be released tomorrow.
                OK thanks. So that brings me back to the original question. If I have Flash 8 and Freedom 1, why would the icons and logo not show up?
                  Maybe you installed flash 8 with firefox too. You where probably using flash 7.
