Minimal Skin Release
  • Minimal Skin Release
    Update - 1st December 2006
    Minimal061201.rar
    - Red frame Video graphic changed to get rid of the girly pink.
    - Video buttons changed.
    - Picviewer previouspic button fixed.
    - some slight positional changes on buttons to support the solid styles.
    - Style change buttons now works for the first time as well as subsequent use.
    cheers
    KPJUK
    Update - 27th November 2006
    Minimal061127.rar
    Walnut Solid style added to config options
    cheers
    KPJUK
    Update - 17th November 2006
    Minimal0611117.rar
    - Update to the XM / Sirius screens from feedback received
    - Added scrolling text into top statusbar
    - Removed a stack of backgrounds to reduce the filesize.
    Can anyone confirm that the following screens work ?
    TV
    SIRIUS
    RADIOSHARK
    cheers
    KPJUK
    Update - 16th November 2006
    I got the config screen working. Its on the apps page. You can now change between three colour frames (more to come)! If you download the latest file
    Minimal061116 This has all three framesets included in the directory called Colours. A few minor placement changes have also been made, and more Background images included. For future releases, I'll trim this lot down, as the download is up at 27MB now !
    Any comments, things you like, things you hate will all be gratefully received.
    cheers
    KPJUK
    Hi everyone, here is my latest skin called Minimal, which can be downloaded from here
    Minimal061115
    Minimal skin
    I have tried to create a semi transparent skin, that you can use with backgrounds of your own choosing. The Backgrounds you want MUST be 800 x x600 resolution, and copied into the Backgrounds directory. You can set the display to change the background on a timed basis, either sequentially or randomly. I have tried to provide Radioshark, XM and Sirius skins, but without access to these technologies, I can't test the skins ! If anyone can confirm that they work, or not, I will try and fix any problems with them.
    I am working on different coloured wire frames that in effect will be "new skins" although part of the Minimal family. I also intend to make some solid backgrounds. Included with this release are red, blue and grey framesets.
    Installation
    Download the Minimal skin, which is a rar file, and unpack it to your skins directory. To get the skin working you will need to install a new font which you will find in the Fonts folder, install screenlock (if its not already installed), install the CD-Rip plugin (if its not already installed), and add a few entries to rr.ini.
    Fonts
    The M Character I use for the Menu button comes from the Greek Diner font which you will find in the Fonts folder. This needs to be copied over to your Windows Font directory for it to work properly, then you can delete this folder.
    Screenlock
    Screenlock is a plug in tool that provides you with as it says, a way to lock your screen. When installed it does this whenever your system hibernates, protecting your system if your car is stolen. To install screenlock, you need to download the plugin, (from here). Instructions for installationof this are included in the zip that you will download.
    RR.ini
    Next you need to make sure that picspath is set to point to your picture directory. I have found that you need to use the 8.3 format to get this working, so
    C:\Road Runner\Skins\Minimal\Backgrounds\
    becomes
    C:\Roadru~1\skins\Minimal\Backgr~1\
    You can also add a Minimal skin specific entry to rr.ini which is
    ButtonPos=1
    This value will be changed by the skin depending on the location of the button bar.
    RRConfig
    Now fire up RRConfig, and set your skin to the Minimal Directory, and you should be good to go.
    Minimal Functions
    The Minimal skin was an attempt to bring customisation to the masses. All the text is implemented using labels, so they can be changed by the user. Background Images are changed on a timed basis, either sequentially or randomly. The backgrounds are selected from the image files within the Backgrounds directory. I have included a few to show you the idea. A file called Minimal.ini is in the skin directory. The ini file has two options to change. A debug flag, and a seq/random flag. It will also show you index of the last background image used.
    To change the background image, click on the Time/Date button. This button has a secondary function. If you click and hold the button for two seconds, then let go, the button bar will move to the bottom of the screen, or back to the top, if its at the bottom.
    The Top right button that show the track time and remaining track time is also a button to activate the visualisation. Click and Hold this button for two seconds brings up the exit menu.
    Screens Implemented
    Main Menu
    Audio Player
    Audio Browser
    Radioshark
    External GPS (For Navigator 4)
    Web Browser (set up to use Opera, a line to use IE7 is commented out in the www.skin file
    Games
    Skin Browser
    Video Browser
    Video Player
    Weather 1 day
    Weather 5 day
    Gamma
    Mixer
    Launch
    CD Rip
    Exit Menu
    XM
    Sirius
    AverTV
    Picviewer
    OSK
    Still to do :
    PHOCO (Just need the courage to tackle this one!)
    GPS Not sure which to do, MapMonkey / Freedrive / IGuidance
    DVD Not sure if this is used !
    More Wireframe colours
    Some Solid colours
    Requests ?
    If anyone has Radioshark, XM or Sirius technology and can test the skin, please post the results/problems here and I will try and fix them.
    Thanks for looking
    KPJUK
    I will post some more later
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Coloured Framesets
    Here are the Coloured Framesets for the Minimal Skin
    Red Frame
    Blue Frame
    Grey Frame
    To install a frameset, unpack the two directories into the Minimal
    skin directory. This will overwrite the current two directories,
    ButtonB and ButtonT.
    Fire up the skin, and press and hold the Time / Date Button for two
    seconds. This will change the colour over, and swap the buttons, do it again to move the buttons back.
    KPJUK
      pics ?
      04 Accord Coupe Carputer
        Pictures
        Give us a chance mate !
        Some pics listed below, I can't remember how to add them so they show !
        I will post some more tomorrow.
        KPJUK
          KPJUK
          either link to them on a website or only upload one per post.
            I thought I had linked to the website this time !
            KPJUK
              Originally posted by Enforcer View Post
              No, you attached them
              Hi Enforcer, your right, I attached them, but from the website ! I knew they had to come from the website, just took the wrong option !
              I just noticed the buttons for the top button menu are set a little high ! the #BUTY# value should be set to 063 in YPos.txt. I have uploaded the right files now, and I missed a ButtonB Directory out of the Red skin, which has also been corrected.
              cheers
              KPJUK
                More screenshots
                Hi guys,
                here are some screenshots:
                Red Frame Top - Menu
                Blue Frame Bottom - Menu with Visualisation
                Red Frame Top - Audio Player
                Red Frame Top - External GPS (Navigator 4)
                Red Frame Top - Games (Games included in download)
                Red Frame Top - Mixer
                Blue Frame Bottom - Skin Browser
                  Better quality jpg's
                  Blue frame, buttons at bottom, with a series of backgrounds.
                    Hmm, it's giving me ideas.
                    This is the transparent gif file I have used, if its of any use. The problem seems to be the load time for each screen, first time around only. Whenever you move the buttons or change the background, I have to call RELOADSKIN, which blows out the memory. If you try and rebuild the screens without the reload, some objects (s) and labels with scrolling text, keep the old image as their background, which screws it up.
                    Still it gives a good effect overall, and makes customisation easier for the general community.
                    Once I have the skins to my liking, i will work on other frames, and button styles. I have some aluminium, vinyl and wood buttons that I have been playing with, but I need to finish other bits off first. . . .
                    KPJUK
                      Got the config screen working, so now all three colour framesets can be changed by clicking the button on the apps\config screen. The framesets are now stored in the Colours directory.
                      Needs a new download I'm afraid ! see the first post.
                      Cheers KPJUK
                        hey man, this is really cool... I did a skin a while ago for centafuse that had the appearance of transparent buttons over a background image, but cf don't really support transparencies, it was an illusion & the graphics were built into each & every button
                        there were tons of guys who wanted to be able to replace the background image with there own, but of course it wasn't possible without redoing each & every psd.... this is really cool, I bet many guys will like this, great job
                          Cheers TurboCAD6,
                          its good to get encouragement when new concepts come out. I called the skin Minimal because I wanted to have minimal interruption for the background images. That way the look can be changed with little work. I have been trying to get transparent images working for an age, and a friend suggested to try the way newspapers do shading colours. I am really pleased with the way its come out.
                          KPJUK
