Video skin question
  • Video skin question
    I'm looking at the video skin and i am not seeing any specs that start with an A for application. The skin .jpg is smaller and fits at the bottom of the screen and reserves the top for the video. But i dont see the video reserved spot in the .skin file. Can you tell me where it is? Also, if i wanted to have text OVER the video, how could i do this? Obviously create a label, but i guess i need to create a label relative to the coordinates of the video window, not the .jpg window. let me know if this is too confusing. feel free to ask clarifying questions.
    Also, where is the file that actually launches the video player? not the menu.skin though.
    the .skin file...
    MEDIACAR Skin
    MEDIACAR Default"Videoplayer" Skin
    video_player_empty.jpg,video_player_off.jpg,video_ player_on.jpg,video_player_down.jpg
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,0,6,65,73,"MUTE","Mute"
    B02,66,6,65,73,"VOL-","Volume-"
    B04,132,6,65,73,"VOL+","Volume+"
    B05,198,85,66,76,"GPS","GPS"
    B06,66,85,65,76,"LIST","Playlist"
    B07,660,85,65,76,"MIXER","Mixer"
    B08,0,85,65,76,"ZOOM","Zoom"
    B09,277,85,62,76,"Up","Prev"
    B10,341,85,62,76,"PREV","RWD"
    B11,404,85,62,76,"STOP","Stop"
    B12,468,85,62,76,"PLAY","Play"
    B13,532,85,62,76,"NEXT","FFWD"
    B14,595,85,62,76,"Down","Next"
    B15,132,85,65,76,"LOAD;LIGHTING_MENU1.SKIN",
    B16,737,85,63,76,"EXIT","Exit"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,0,162,800,28,000,162,800,28,H,00,"SLIDER3\POIN TER3.gif",12,"VIDEOPOS",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,206,6,45,35,255,127,000,18,"Arial Narrow","TRACKNUMBER","Track number"
    L02,256,6,416,35,255,127,000,18,"Arial Narrow","TRACKNAME","Track name"
    L03,310,64,50,19,255,255,255,10,"Arial Narrow:B","VOLUME","Volume"
    L04,374,61,80,22,255,255,255,11,"Arial Narrow:B","STATUS","Status"
    L05,462,61,70,22,255,255,255,11,"Arial Narrow:B","CURRENTTRACKTIME","Current track time"
    L06,540,61,100,22,255,255,255,11,"Arial Narrow:B","TRACKTIME","Total Track Time"
    L07,673,12,120,29,255,127,000,16,"Arial Narrow","TIME","Right"
    L08,659,43,134,29,255,127,000,16,"Arial Narrow","DATE","Right"
    END
    Well there should be the following in the video_player.skin
    A01,200,42,600,500,192
    C01,200,42,600,500
    for it to work. Although I suppose if you don't have that when it first loads the video will be hidden until it skin disappears for the video to become full screen.
    text over the video cannot be done (as far as I am aware)
    to launch the video it is normally in the menu.skin and the command is video
      id like to know this also. Im trying to make some ... clever mods for video player but it wont work as I cant get a secondary skin to load play the video
      Car : 00' Chrysler 300M
      Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
      Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
      CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
        video will only play in the video_player.skin.
        if you set dualmon=true in rr.ini then video will continue to play once you have left the video_player.skin as long as you don't go to audio_player.skin or radio_player.skin
          well damn... that kindof sucks.
