StreetDeck / Hmonitor incompatibility
  • StreetDeck / Hmonitor incompatibility
    I use a utility for monitoring temperatures, fans etc on my EPIA motherboard called Hmonitor. It's a neat utility and let's you set alarms on failure (or soon to be) conditions. I have used it for a couple of years. NOW, when I run StreetDeck, I get an error from Windows about HMonitor having a EPriveledge execution error right after I run StreetDeck. This is true for 1.0.5.0, 1.0.5.1 and 1.0.5.2. I have never run a pre 1.0.5.0 version of SD. I have not posted this to Hmonitor as SD is the only app that I have eve run that has caused an execution priveledge fault.
    Any ideas? (Other than to not run Hmonitor )
    SLOJAM
    1972 'slightly enhanced' 240Z
    Epia M10000 Win XP
    Creative Soundblaster Audigy 2 ZS
    7" Touchscreen XMPCR GPS
    Try running with -gdi
    If possible try running StreetDeck and Hmonitor on an entirely different computer to isolate the problem futher.
      speedfan doesnt like SD either
      I use speedfan to monitor temps and such, and when I load SD it causes all the EPIA specific temps (hd temp stays) to goto 32F.
        MBM5 has no issues with streetdeck.
          Tried -GDI and still causes the issue. I don't mind running SD without Hmonitor, but my experience is that there is an underlying issue and it will rear its head elsewhere...
          SLOJAM
          Epia M10000 Win XP
