streetdeck crashes when i click on 'Select this Artist'
This topic is closed.
  • streetdeck crashes when i click on 'Select this Artist'
    What version of StreetDeck is this bug report for?
    1.0.6.3
    Please give a basic description of the issue here.
    Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    yes
    If no, please describe your system here.
    Please provide any relevent information regarding the issue you have encountered.
    After selecting a genre to play on the music module, I proceed to click on 'Select this Artist' or 'Select this Album'. Streetdeck always crashes after click on either buttons.
    I experienced a similar crash today. After using SD (1.0.6.3, same verson as poster, system I'm running is the same as my listed specs) for 10-15 minutes without issue, then I highlighted "select this artist" using the keyboard and pressed enter...hard crash.
    An amateur built the Ark. The Titanic was built by professionals.
      Yep, same here (same version). Actually I had the same problem with Select this Artist and Select this Album ever since I installed the software in December.
        Should be fixed in 1.0.7.5 or later.
