Audio input sound Card not available in Xm settings - 1.0.9.8
This topic is closed.
  • Audio input sound Card not available in Xm settings - 1.0.9.8
    What version of StreetDeck is this bug report for?
    1.0.9.8
    Please give a basic description of the issue here.
    Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
    Yes
    If no, please describe your system here.
    Are you able to reproduce this bug at will?
    Please list the steps required to recreate the issue you are reporting.
    Please provide any relevent information regarding the issue you have encountered.
    My mobo has a Realtek hd soundcard and im unable to select the correct sound card & audio line input in xm radio settings, but i can view and select them in the bluetooth mic settings. SD also fails to mute my mic after a voice command
    Issue resolved. SD is functioning as designed.
