Brainstorm - a distributed car install
  • Brainstorm - a distributed car install
    My install sucks. Touchscreen, pc, audio (yawn). I'm on my third pc at least and all the patching and adding has introduced a wicked ground loop that won't quit. The whole thing has got to come out and be rebuilt.
    But I don't want to put the same old boring setup back in. I want to do something different and that's where I want to brainstorm with everyone.
    I want to build a distributed system inside the car using a WiFi hotspot to connect as much stuff as possible. At the heart of the system, I plan using a sheeva plug Linux computer. This plug has no video output but it has USB port and an ethernet connection.
    I want to use the plug to connect to the gps, the obii port on the car, and to an external USB drive with the music stored on it. I'll also keep the gps and obdii data on it.
    One thing I'll need to figure out is whether I can run a media server on the sheeva to serve the music up. Right now, I'm able to access all of my music on a home computer using a program called dot.tunes that streams the songs to my iPhone. I'd like something like that for the sheeva.
    For display, I'd like to use my iPad. Either I will see about using a web page served up from the plug or if necessary, may have to program a front end app. I'll stream the music to the hu via a Bluetooth dongle I've got. I'd replace the hu with an amp but it's a vw monsoon system that would be a pain to replace.
    Internet connectivity would be via MyWii that allows tethering using the iPhone as a hotspot.
    That's the plan for now, at least. Suggestions are appreciated, particularly on the software side.
    [Update: Progress so far]
    1. Installed Mediatomb, a upnp player on the Sheeva Plug without incident. The plug is now available to any upnp PC on the network. App for iPad/iPhone tested for audio. Wireless streaming to a 'head' unit of either iPhone or iPad is now possible and Bluetooth connectivity to stereo will enable wireless audio.
    2. Hacked dash to bits. Prototype cradle made for iPad screen, working on fab.
    3. Rebuilt the iBug computer to integrate Sheeva plug, built power distribution box, converted Sheeva to 5 volt DC power, converted Apple Time Capsule to 5v/12v dc power.
    Want to:
    Make sure your bluetooth dongle supports A2DP or it will not transmit stereo audio.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
      Thanks. The dongle is currently in use with my iPhone install and works great. I have to mod it so that it is powered by the car battery but beyond that it will work fine.
      Want to:
        not sure how much it helps, but i read somewhere that someone made a driver for the sheeva plug to use a usb touch screen..
        next project? subaru brz
        carpc undecided
          Assuming the ipad follows any standard (and thats a big if)...theres a few different media players for linux that can push a music library.
          openMobile - An open source C# Front End (why choose openMobile?)
          - Always Recruiting Developers -
          Like what you see? Donations are always welcome
            I've been thinking about this very thing. My setup will be quite a bit different than yours, but wanting to accomplish the same. I would like multiple low power devices for different duties, I'll be starting on it probably the end of June.
            I'm interested to see what you come up with for the sheeva plug and serving music. I thought about going the uPnP route and Twonky, but now I'm thinking I may want a box that plays the music locally but is controlled remotely similar to the way XBMCs remote control works over http.
            This is really just a long winded way of saying... subscribed.
            Tidder
            Try RevFE
              Tidder brings up a good point, can you toss xbmc on your Sheeva? and then use the web interface? i believe the ARM support is in its infancy but since you're not looking for video streaming [ATM] it should be good, although it could be a bit of [disk space] over kill, but the web interface can be browsed via your ipad and should stream music to your box via w/e audio "card" you set up.
              I've also been using a nice project called Ampache at home that is a web based jukebox, might be cool
              MobileThree: in car - Zotac Atom/ION - linuxICE 2.0.2
              --worklog--
                I've personally used mediatomb with great success.
                If you want to spring for it, there's a new sheevaplug lined up, same form factor as your current one, but with an HDMI port and a couple extra USB ports. GuruPlug Display. They have a bunch of other models under the guruplug moniker that might also be good for you.
                Call it an educated guess, I suspect that'll work pretty well :-)
                Gary (-;
                OBDGPSLogger, for logging OBDII and/or GPS data
                OBDSim, an OBDII/ELM327 software simulator
                mp3car forums: obdgpslogger, obdsim
                  Thanks, guys. So ampache or mediatomb sound like two possibilities for now. I'd rather not mess around with xbmc unless it is a little farther along.
                  So, to run them on the Sheeva, I'll need to download the source and compile them, no?
                  1. Ampache - runs on apache server using sql and php. You can access it via web pages it serves up. There is an iphone app you can use to access it as well. It appears that Ampache streams music rather than transcoding it.
                  2. Mediatomb - not as clear as Ampache but I found a section that says it runs on the ARM processor. It also serves up via web pages for playback and streams rather than transcodes.
                  I'm not sure I understand what upnp has to do with it, though? Isn't that some kind of standard to allow devices to find each other on the network?
                  Want to:
                    Upnp is universal plug and play. Its supposed to be a cross-platform way for devices to advertise themselves and the services they offer on the network. On top of that is the upnp av layer which allows your devices to act as media servers, media playback devices, etc. It handles all the streaming, control and browsing in a standardized way. Its used by most of the major players and even household devices like tivos.
                      uPnP was just an idea I threw at myself out loud. There are quite a few uPnP media servers out there: Twonky Media Server, MediaTomb, uShare, etc.
                      Sounds like you need to do some reasearch on uPnP.
                      Heck, there might even be a uPnP iPhone app for streaming media.
                      EDIT: Well, I'll be danged. http://www.plugplayer.com/
                      Tidder
                      Try RevFE
                        Or just log into the plug and "sudo apt-get install mediatomb"
                        Gary (-;
                          Thanks for that, chunky. I've installed mediatomb on the Sheeva plug and it actually let me log on to the server from my desktop machine.
                          Now, I'm looking at the plugplayer app that Tidder pointed out. I don't really know how this stuff works but I presume I ought to be able to load it on the iPhone/iPad and if I'm on my WiFi network it will discover the mediatomb server?
                          I'll let you know.
                          Want to:
                            Damn! That worked waaay too easily!. Mplayer lite was free on the app store so I downloaded it to my iPad, launched it and it found the plug instantly. I added an mp3 to mediatomb via ftp as a test and not only did it show up but the tags were read properly, giving me a pretty decent interface right off the bat.
                            When my external drive arrives, I'll put all the music and video there and point mediatomb to it. That should solve my music player issue through local streaming. I need to look into the docs to see if I can stream music from a web location like a PC at home. I'd be surprised if you can't do that.
                            Want to:
                              Yay!
                              Gary (-;
