Buidling OPAL library help
  • Buidling OPAL library help
    Could someone try to give me a hand with our new software? After some tests, we came to the conclusion that it is now time to integrate a VoIP solution into our software. I am trying to use XMetting as the base for the module, but I simply cannot get the required opal library from OpenH323 project to build on OS X.
    So if anoyone could build this library, I would very much appreciate instructions on how to do that.
    And by the way: all the code in the VoIP module will be open source...
