Powermate Griffin
  • Powermate Griffin
    Hi all- i was wondering if anyone could help
    After a lot of searching, i still couldnt find the answers
    My problem - getting the powermate to emulate the escape key.
    Using the standard controls in pref pane, and using proxi, i cant get it to register the escape key. Instead, it always thinks i've pressed the eject key. I'm using a macbook, so i plugged in a usb keyboard, and its still the same. I can get the powermate to do any other button- just not the escape key. nice one griffin.
    I'm trying to get it to control front row- it all works fine, except i need it to activate the escape key to go back to previous menu.
    Is there any way around this? Or would anyone have a proxi blueprint for getting the powermate to control frontrow 2?
    Should i junk the powermate and use something better?
    Any help would be much appreciated!
    This is the last hurdle i need to overcome to complete my mac in a car setup. :-(
    I'm using a touchscreen, but the powermate would have been nice for navigating front row as im driving.
    i don't think that the griffin software allows for the escape key (have you checked for updates). I also know there is some software floating around here that can help with that. I don't recall it name, however.
    check us out at: www.neonboombox.com
      You cannot map the escape key to the Powermate without to use of Proxi, which works great for controlling Front Row in Leopard.
      Look through your system preferences -> Keyboard and Mouse -> Keyboard Shortcuts and see if there is a shortcut that is making the escape key map to eject. That is NOT the proper or normal behavior on any Mac by default. Eject is a dedicated button, or hold down F12 on older keyboards/Macs with no dedicated Eject button.
        Thanks for the replys. Ive checked in keyboard shortcuts- theres no conflict.
        I've got proxi to control the powermate for front row, in every way but going back to the previous menu. The symbol that comes up when i try to map the escape key to a function, is a circle with a little line coming out of the top left- which, after a little researcg, i found is the symbol for the escape key. However, i just cant get the powermate to go back a level in frontrow. just wont work!
        Any chance you could share the blueprint file for proxi, if you have it working?
          I'm using version 1.51 of the Griffin Powermate pref panel and it maps the escape key in Front Row. It shows up as 'esc' when you set it in the send key window.
          Want to:
            Strange- according to Griffin, its not possible to map it to the esc key. What computer and keyboard have you got?
            Heres the email i recieved form them on the subject:
            Are you running version 2.1 of the PowerMate software? As for the ESC
            key not being able to be programmed in, this is an issue inherent in the
            ESC key. Your computer will try to escape or revert when you press
            that key, regardless of the fact that you are pressing it in an effort to
            program it rather than actually escape. Your computer does not
            understand the difference. If it were possible to temporarily disable the
            escape key, program it into Powermate and then re-able it, that would do the
            trick but I am not aware of a way to disable the ESC key to do this.
            However, maybe you can go to: System Prefs --> Keyboard and Mouse -->
            Keyboard Shortcuts --> and Untick "Hide and Show Front Row", then program
            it in PowerMate, then go back and re-rick it. I'm not sure if this
            will work but its worth a try. Also, I did some reading and it seems like
            on some systems F1 can perform the same function as Control+ESC does
            for Front Row. If your system does this, then that would be another w
            ay to approach this.
            Currey
            Griffin Technology
            Technical Support
              That's a BS. Of course you can easily intercept *any* keystroke including modifiers and process it any way you want in your program - and this applies to both Cocoa and Carbon.
                Mac Mini 1.42 PPC and one of those indestructable keyboards that rolls up.
                Tell them to send you version 1.51 of the software!
                Want to:
                  Managed to get it sorted- no thanks to griffin!
                  I used Proxi to program the powermate to do what i want. took ages, but proxi will register the escape key.
                  Hmm- so proxi will register it, but the powermates prefpanes controller wont. but both programs are made my griffin. hmmm, i smell bad programing.
                  If anyone reads this in the future, and is having problems using a powermate with frontrow, give me a shout
                    I would like to use a controller to switch Spaces desktops (to switch between Neon BoomBox and Garmin Mobile PC running in Fusion) and I mistakenly thought that the PowerMate would do it. The PowerMate software won't pass modifiers with the keystrokes and I can't figure out how to use Proxi to do it either. (Proxi is not very intuitive software. I'm sure it can work somehow, but I'll be darned if I can figure it out).
                    So, can anyone help me with Proxi, or do you know of a controller (not a keyboard) that will pass modifier+keystroke to Spaces?
                    Any day is a good day for golf.
                    Mazdaspeed6 Carputer Progress: Gone
                    (Check Speedy's Install)
                    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
                      well i don't know how to do that but if you can do it with apple script you can drop a script called launch into the sample modules script folder (available in the NBB SDK thread) give it a different icon and drop it in the NBB modules folder and use it as an "Embeded" module.
                      I can help you if you need it. The sample project is incomplete and needs much more work, but that is its intended purpose; to "embed" 3rd party apps into NBB
                        This will do it.
                        http://www.mp3car.com/vbulletin/macc...ml#post1231022
                          I set the Powermate to send the keys Command-Right Arrow when held down for 2 seconds, then set Spaces to use that key combo.
                          The Mercenary Missileer's 2000 Toyota 4Runner Highlander Edition
                            But how did you get the PowerMate software to take the Command character? I can't get it to take any of the modifier keys.
                              That's odd, I couldn't get it to take ESC or any of the F keys, but it would take Command-Right Arrow from my keyboard.
