Quicktime Surround sound?
  • Quicktime Surround sound?
    so I know the Quicktime application can play surround sound audio from movies and I can only assume the same is true of properly crafted audio files. My question is: if I am using the quicktime frame work in an application do I need to do anything special to take advantage of 5.1 audio? Does the QTMovie object handle this setup on its own? I cannot find anything using google, and I know mac FEs other than my own use quicktime for audio playback; I am hoping one of the other devs knows.
    I don't have either the hardware or a test file, but if nobody knows the answer would somebody be willing to test my software with a a 5.1 audio file that works as 5.1 in quicktime player? I would be very grateful. I am ever so curious if 5.1 audio is functional or can be functional in NBB.
    It may influence my decisions when i finally get around to buying my hardware for my car.
    check us out at: www.neonboombox.com
    Full surround is a pain in the neck. Long story short - yes, you can just use QTMovie to play multi-channel tracks, that's not a problem. The problem is that you cannot easily use the built-in optical audio out port and external sound adapters usually do not allow you to control the volume, so you need a suitable (pre-)amplifier to do this.
      wow thats nice to know thank you.
      Do I have to do anything special (call a certain function/ use a certain initializer) to playback 5.1? or is initializing a QTMovie object using a 5.1 file enough? is it safe to list 5.1 audio support as an application feature?
      do you have any hardware suggestions for playing 5.1?
        Hi NeonDev, it seems to me that its fairly "auto". As in when i plug a regular 3.5 stereo jack into my Mini, it'll play in stereo but when the TOSLink goes in (and as long as your amps are capable of TOSLink input), it plays/splits into the 5.1 channels just fine.
        And yes, no volume control except on the amp.
        I've tried this with Quicktime and am currently using CFE as a frontend, but would really like to give yours a testdrive.
          I would appreciate that. ;-)
          I'm definitely curious if it'll do it. kinda sucks that you can't control the volume... why is that exactly?
            The 3.5mm stereo plug uses relative voltage as a volume (i think) so if you lower the volume, while the waveform (of the music) remains the same, the amplitude comes down.
            The Toslink's signal is digital - 1's and 0's, so no volume embedded in the signal. In your digital home theather system, you can't tweak the volume from the DVD player, but from your amp - so same case here.
            Having said this, you can tweak the volume on Quicktime (not system volume) and the volume actually changes. I don't know how this works....
