DVD in Fusion
  • DVD in Fusion
    Is anyone else using fusion having trouble getting a dvd to play. I have tried everything I caould think of and find on the net. Fusion says something about DMA or something, Im not sure of the exact msg right now. Does anyone know how to fix this?
    I don't have an answer, but a dumb question:
    Why do DVD playback in Fusion?
      um....cause im using a windows front end
        Just curious
          With all the issues you've been having, it may make sense to use Bootcamp rather than fusion. If you can get everything to work right in Fusion, more power to you. I wasn't able to and decided to cut bait.
            yeah thats what I was thinking last night...I havent looked into it yet but is it possible for the two partitions to access each other
              I know you can use fusion to access a bootcamp partition. I don't believe a OSX partition is accessible through WinXP. I didn't even create an OSX partition, just installed windows right onto my mini.
                here is something that may help you
                check us out at: www.neonboombox.com
                  Windows does not come built in with software to decode DVDs. That is probably what you're running into. Booting into Bootcamp/Fusion shouldn't have anything to do with it I would imagine.
                    so i need a dvd program...I can't just play a dvd with media player?
                      yeah with windows you have to have a dvd decoder. windvd or powerdvd or something like that for it to work. if i remember correctly a lot of dvds have that software on the disk, and will try to install it when you insert the disk.
                      Check out the new version of NAS, a cross platform music frontend here
