Repackaging Mac Mini
  • Repackaging Mac Mini
    Hey Guys,
    I am looking at installing a carputer in my 2007 GTI. I was wondering if the mac would still work if the case is removed, and the innards are put in a custom case.
    Thanks,
    Azhagan
    It will work fine if your can provide it with at least some air for cooling.
      Sure, why not? It's just an Intel based PC.
      My stagnant project
        Thanks for your answers. I was just worried that with the proprietary nature of Macintoshs that somehow you couldn't run the system keeping the case open.
          Just curious why you want to repackage the Mini?
            Well I have a buddy that can get me an old XServe Cluster (the ones with only one drive bay) shell and i'm been thinking about putting the guts of a Mini in it just for the hell of it. Can't find a place that it will fit in my car though
            -dave
            My pathetic worklog.
            CarFrontEnd (now it's own sub-forum!!!!)
              Yup, been there, done that. I bought a center console and the Mac Mini fits perfectly.
                You must have that thing ventilated, right? How do you keep it cool?
                Want to:
                  So far, no problems. Doesn't seem to run particularly hot. The bottom of the storage compartment has been cut out. The console is meant to be installed by cutting away the flooring for a flush fit. Since I didn't, there's a good bit of gap along the sides of the console that's hidden by the seats. I had a professional install the Mini & the head unit into the console. He was going to install a cooling fan, but after measuring some temps, he decided it was unnecessary. I went on a 7-hour trip this weekend and it never felt even close to the temperature of my laptop.
                  Bottom line: time will tell, but so far I'm cautiously optimistic.
                    I guess it depends on if the foam covers the whole Mini and what the climate of your area is. If the foam completely covers the bottom of the Mini, then it will have issues circulating air when it needs it (in through the bottom, out through the back).
                    Really nice looking area you have there though. Very clean.
                    -dave
                      Seven hours is long enough to figure it out!
                      If you're curious, run temperature monitor on it. It only gives you the SMART disk temperature, but that's a good proxy. I've found that if it gets much over 130 F you will get a shutdown.
                      Want to:
                        I would like to fit it somewhere behind the dash, and I can only do that without the case.
                          That is a sweet setup!
                          "Imagination is more important than knowledge." -AE
                            i would think the mini would prob run a lot cooler without the case. the only problem i could see would be leaving the internals open to the elements, but im sure it would all work just fine.
                            Check out the new version of NAS, a cross platform music frontend here
                              It's no different than what many users have done other components.
