my new carputer plans
  • my new carputer plans
    someone let me know if there would be a problem with this...
    streetdeck
    macmini with dual boot
    windows xp
    transflective touchscreen
    microsoft streets and trips gps usb
    i want to wire up the mac mini so it will turn on when the car turns on, and go to sleep or shut down when i turn off the car. how do i do that?
    i also need the mac mini to somehow transfer music from the computer to my amp to my speakers and sub.
    any help would be appreciated
    also, any suggestions on the specs of the mac mini i should get? the higher the better? or would a top of the line mac mini be draining too much power from my battery?
    If you're going to run streetdeck, don't bother with a dual boot, waste of HDD space.
    www.carnetix.com for a macmini compatible smart power supply.
    Are you going to run with or without a headunit?
      Headphone jack to RCA jacks. Or you could get a usb audio device of some kind. I'm satisfied with just the headphone output.
        why shouldn't a run a dual boot? i thot streetdeck was only compatitble with windows?
        as for the headunit question...i'm not sure yet...any suggestions to why i shuld or shouldn't?
        sorry for the noob questions everyone
            @Streetdeck: I use Streetdeck as my frontend and have been very pleased with its performance; however, you should be aware of a current lack of support from its creators. I dont regret my purchase, just something you may want to consider before spending that much money.
            @Headunit: I removed my headunit and put a touchscreen in its place since the computer would do everything the headunit did and more. Unless you have a real reason for keeping it, relocating it is probably more effort than its worth.
              ^^ i had streetdeck on my last car and i am aware of their horrible customer service, hopefully, i won't need it if i do it right the first time
              as for the headunit, i think i'll agree with you on this one, however, the only reason i would want to keep the headunit is because it will make the job easier to wire up my amp and speakers and sub, and also if there is a problem with the computer, i can still listen to music through the headunit
              ^^^ if you don't mind me asking, what is your exact setup?
                You can click on it under his screen name.
                Want to:
                  oh nice...wat's PPC? it's under your specs for the mac mini
                    its for Power PC chips (ie not intel), therefore he cannot boot any x86 OS like windows. You will need an intel one to run street deck.
                    check us out at: www.neonboombox.com
                      ^^^ gotcha, thx for the quick response
                        I'm pretty sure you can just install windows only on the intel mac. You may need the leopard drivers though. I think a few people have done this.
                          Not if you run Parallels or VMWare fusion.
                          Yep, just pop a windows disk in and install away. The drivers off the leopard disk are pretty much a necessity. Although you can hunt down all the drivers off the disk for free if you wanted to.
                            you can't run parallels or fusion on PPC machines
                              That's odd, thanks for the correction.
