Alpine IVA-D310 + MAC MINI
  • Alpine IVA-D310 + MAC MINI
    My first time posting here. I currently have an Alpine IVA-D310, w/ Alpine BlackBird II/docking gps. I plan on adding a mac mini to the IVA-D310 via rca audio/video inputs. The alpine is a touch screen to select sources but I know it will not have any capabilities of controlling the mac. The thing is I don't really care. I have looked at the touch screens this site has to offer, and no offense to anyone but man these things are ugly. If i can select the mac mini as a source i can still use keyboard and mighty mouse to control it, and volume via the head unit. So I have some questions for all of you seasoned professionals:
    1. Am I right that I can't control the mac mini via touchscreen on the
    head unit (i'm positive this wont work since it is simply connecting the
    video/audio out of mac mini to display on head unit screen)?
    2. An extension of the first question, is there any module/software i can
    add on to head unit that would enable me to control the mac mini
    rather than just viewing its output on the screen?
    3. I live in Iowa so its 90 - 110 in the summer, and -15-40 in the winter.
    Has anyone had any issues with moisture or cold/heat issues when
    operating a mac mini? If so, what is your resolution?
    4. Rather than using a bluetooth mouse in the car i would like to
    integrate a touchpad. I know this would be pretty advanced but is it
    possible to take an apple touchpad (part purchased straight from
    Apple) and connect it to mac mini? I would then flush mount it in
    center console.
    Let me know what you guys think, or of any advantages/disadvantages? Thanks for the help.
    well i can only answer the first question: you will not be able to control your mini through the alpine.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
      This works great for your touchpad ? I live in ohio and haven't had any problems with the temps.
      http://www.ergonomictouchpad.com/erg...FQNfFQodygy8JA
        Correct.
        None that I am aware of.
        I haven't had any issues operating it in New York or Virginia for the past several years.
        center console.
        You can buy those mini touchpads and connect them via USB. This would solve your issue for number 1.
        Controlling your Mac via touchscreen isn't the best way to do it, IMHO. I've tried all types of controls and found that the simplest is the best. A rotary controller like the Griffin Powermate and a good front end that lets you scroll and select easily can't be beat.
        The problem with touch screen is that you have to look at it to operate it. A rotary controller allows you to scroll down without looking, pause without losing your place and glance at the screen, then select the right command or song.
        Others will have other opinions, but I've found a rotary controller to be the best for me. Try that and combine it with the trackpad for close-in work before working too hard on a touch solution.
        Want to:
          I'm not sure if I overlooked it...but it would be possible for the mac to output video to the Alpine? Does anyone have an example of the picture quality this would produce?
          I really hate most of the touchscreens out there...and I have fallen in love with the new macbook. If I could get an alpine and have the best of all worlds...I would be in heaven.
          Over a year later I guess it's true...a carPC is NEVER complete
          2002 Mustang CarPC
            Yes, unless you are ready for some very serious hardware hacking, you won't be able to use the touchscreen.
            Not that I know of. You would have to design an build it.
            No problems so far, just make sure there is enough air flow around the place where the computer is installed - no tight closed spaces.
            center console.
            No, the trackpad itself does not contain the circuits necessary for USB connection. Use NuLOOQ, SpaceNavigator, Shuttle pro or similar device instead.
              There are converters for the Mini (scan converter is what you are looking for) but the picture quality will be a compromise.
              Obviously, it can be done. The AppleTV does it. You would need to lower the resolution of the display and stick with specific color schemes. You'll be surprised at how little information you can get on the screen compared to a regular VGA screen. This thread has pictures of screen quality.
              Want to:
