USB specific advice for Fusion?
  • USB specific advice for Fusion?
    I'm using Fusion in the car and it works quite well, although I'm having an issue with it recognizing the GPS, which is a regular NMEA compliant GPS that uses the prolific serial bridge to USB bridge. I've been able to see and connect to it, but then sometimes after restart, I can't. I haven't had much time to look into the problem.
    Also, the touchscreen works quite well on the Mac Mini, but doesn't even show up as a device on Fusion, so I can't use it on Windows apps.
    Does anyone have advice on anything special needed to deal with USB ports and Fusion?
    Want to:
    I'm assuming your talking about VMware Fusion.
    Do you have VMware tools installed?
    When you restart, are you suspending the virtual machine or shutting it down?
    It probably doesn't connect the touchscreen because it sees it as a mouse and tries to share the cursor like it would share a standard mouse.
    What version are you using?
    xb_mini
      i was about to make the same suggestion. it sounds like the vmware tools is not installed correctly. fusion shouldn't really need to see the touchscreen at all. it should just assume whatever you are using as a mouse in your host is indeed a mouse, and the clicks respond accordingly. as far as loosing the usb after restart, that is why i use Virtualbox in my car. it has an awesome setup known as 'usb filters' where on restart or reboot, it looks for all devices in its filters and automagically adds them to the vm. as far as fusion is concerned though im not sure how you would automatically "give" the usb to the vm.
      Check out the new version of NAS, a cross platform music frontend here
        I do have VMware tools installed. For testing purposes, I've had both a touchscreen and a mouse connected. I've also found that it has trouble seeing a hub I have connected to it.
        Want to:
          What version are you using? If you have recently upgraded VMware make sure you upgrade the tools also.
          I agree with natedawgg. VirtualBox is a great piece of free software. If you continue to have trouble with VMware, you may want to try it out.
          xb_mini
