Carnetix P2140 starting mac mini
  • Carnetix P2140 starting mac mini
    Hello all
    Today i got around to installing my mac mini car computer with P2140 PSU/controller
    When i tested it with a powersupply a few weeks ago everything was working as it should
    now when i turn on the ignition, the p2140 powers up and starts flashing but it never triggers the mini, i can manually short the pins on the switch cable and it will start no problems
    any ideas why it would not be automatically starting?
    thanks
    Luke
    Most likely, you don't have the power supply wired properly. Check your connections.
      Power supply is wired pos to pos, ground to ground and yellow to acc
      connection from power supply is via mac pac prewired cable
        You'll probably want to hook the 2140 up a computer via USB and see what it's doing with the PSUmoni software.
          Check out this video to see if it helps
          http://www.carnetix.com/P2140/Led-sequence-normal.wmv
          Sound System () 100%
          Power System () 100%
          MacMini Setup () 100%
            The 2140 can sometimes get 'scrambled' -especially during testing or if your battery goes dead. Hook it up to the USB and reflash it. That may do the trick.
            Want to:
              It appears it was a broken green acpi wire on the 'quality' mac pac cable
              soldered it back on the plug and that problem is now solved
              Now i have an issue of that it is sleeping my mini fine but then after around 1 minute its cutting power to it
              software is set to sleep mode
