800x600 Xenarc...squished on wake
  • 800x600 Xenarc...squished on wake
    So, why does this happen every once in awhile:
    When I bring the computer back from sleep, or turn it on, or whatever...it gets a signal and turns on with the image on the screen normal...then it says PC then 800x600 and the screen squishes either to the left or right so that a good 1/3 of the screen is blank.
    Odd thing is that the touchscreen works just as if the screen wasnt squished. Pushing the bottom left corner (even when part of the 1/3 empty space) activates the button in the bottom corner for example.
    Makes sense...and yet it doesnt.
    Sometimes bringing the computer to sleep and waking again will fix this issue. But its kind of annoying.
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    xport has a feature called "VGA SYNC" use that, it will fix it
      I have the same issue, I've found that coming up with a fresh boot rather than hibernation fixes it... I'm curious what xport does to fix this so I can have the fix without having to run xport. Anyone have any clue?
      Is xport available for mac?
      RevFE
      My Shop
        use a command line to change the resolution to 1024x768 on startup and then change it back to 800x600 5 seconds later..
        google you will find command lines to do that
          I dont see how that helps when coming back from sleep at all.
          (All done)
            did u try it?
              You want me to run a command line when the computer wakes from sleep...as in run an applescript terminal command (you are aware this is for OSX, might matter?) that is set to run for on wake and startup (ive no clue how to do that)
              (All done)
                download the latest xport, an enable the video sync function. Most likely will fix your problem.
                  try this
                  when the problem appears..go into OSX settings and change the resolution back and forth and see if that fixes it..
                    Try XPort
                    It shuts off the video output for a very short period causing the monitor to synchronize again. See if there's a way to do it in Mac OSX.
                    Possibly this or the power button on the monitor.
                      doh! i just realized this is the mac subsection. ignore my stupid post haha.
                        Where can I download XPort?
                        iC3
                        Citroen C3
                        progress ##### 50%
                        ICE3
                        ITALY
                          You can download xport from curiosity's sig, or here is the direct link:
                          http://curioustech.home.insightbb.com/xport.html
                          to the OP, i'm not sure if it'll apply to your case, but i had a lilliput doing the same thing, and all i had to do is change the resolution to 1024 instead, and i had no problem since. maybe give that a shot.
                            that Seems to be a common questIon GoiNg on in threAds That i'm sUbscRibEd to.
                              But it is for Windows! Is there something similar for MacOs X?
                              Because something when I start my CAR the computer wakes but the monitor not!
                              iC3
                              Citroen C3
                              progress ##### 50%
                              ICE3
                              ITALY
