DC-DC Car Power for Mac Mini
  • DC-DC Car Power for Mac Mini
    We have confirmed that the Mac Mini power requirements will be compatible with the upcoming P1900. We'll keep you informed of the beta test status and availability information as it becomes available.
    MikeH
    Aw man! Hey mike would you consider a trade in with my P1260 that i just bought and havent installed yet. haha Can't wait to see this in action.
    -matt
      ....sooo...you trading your mobo in on a Mac too?
      MikeH
        Quite possibly, first I'll just get the mac, then I'll make the call, looks promising, my uncle and I have been looking into it for some time. I just sent him the link you posted, I'm sure once he sees it he's gonna freak out. Thanks so much, you guys rock!
        -matt
          Mike do you think this will have enough power to power the mini mac(80 gig version), 2 lcds (1 ts, 1 not)? I'm eager to see what I can do with this thing!
          -matt
            Probably. The P1900 can put out 6.3 amps @ 19V (or 20v, or 18v) plus another 15 watts @ 5V on the secondary output. If you jumper the secondary output to provide +12V instead of +5V, the total of both the +19V and +12V equals 120 watts. 85Watts max for the Mac leaves you with another 35 watts. You can draw about 2+ amps from the +12V (24W)secondary output so powering your 2 screens probably won't be a problem.
            MikeH
              No Hibernate mode for the Mac Mini
              Guys...
              We're going to have a bit of a problem with "hibernate" (aka "Sleep") on the Mac Mini. There does not appear to be a "power off" state similar to the PC's Hibernate, where the machine's state is stored on the hard drive. The Mac Mini's Sleep mode requires that power be continually supplied to the Mac during sleep to keep the ram alive. If power is removed during sleep, the Mac will boot from scratch...which is ok, except it takes quite a while.
              The Mac's sleep mode is very similar to the PC's "Standby" mode, which means there will be continuous current drain on your battery while in Sleep. The current drain will be between 150mA and 210mA, which is considerable and can quickly drain your battery (over a few days). This is a problem.
              One way to use Sleep is to only allow the Mac to Sleep if you are only going to stop/turn off your system for a short time (ie gas stop, etc.), otherwise for longer stops (over nite) send the Mac into full Shutdown. This is a bit of a pain, but it's probably a decent compromise...
              Thoughts?
              MikeH
                Hmm maybe you could have the mac mini sleep for 10mins then after 10mins it cuts ALL power off?
                altho that be a bit annoying cause even if its 10mins its a drain for people who dont use that feature.
                I'm not sure what you can do i think the only feature you can do is put it into sleep then turn it off.
                Also could you give me the amount of pins on the power plug and the pitch spacing between the pins?
                I've got a few online stores that might stock it but need some info on what to search for u
                CarPC Status:
                GPS: 99%
                Hardware: 99%
                Software: 92%
                Case Install: 99.9%
                Dash Install: 100%
                Car Install: 72%
                  There are a total of 10 pins, 5 on each side. They are spaced at approximately .06" apart. Outside dimensions of the metal part of the shell are .420 x .160".
                  If you find this part please let us know. This, and the ACPI header connector are the only thing holding us up.
                  Here are pics.
                  Thanks!
                  MikeH
                    Sad to hear about the hibernate problems. NiN^_^NiN`s idea about first hibernating, then shutting down is a good idea. It would also have been great to be able to individually set how long it stays in hibernate-mode before shutting down. I know 10 mins is way to short for my use.
                    I dont know whether the "shutdown while in hibernate" is harmful to the machine in any way, but that can easily be sorted out.
                      Would it be possible to set OS X to shut the Mini down after x seconds/hours/days? I`m currently running OS9 on my pismo, so I can`t find out ;o)
                      How big of a problem will the current draw pose to a system with a second battery? Will the battery lifespan be significantly decreased? After all, i use my car at least once a day...
                        I'm going to have to admit....I am not a Mac guy ...so others will need to answer this.
                        A second battery would prevent your main battery from draining. However, the problem will be a reliable way to keep it charged. This is been debated to death under the power supply section of ths forum. There may be a way to do this, but it gets a little messy. I guess it depends on how much you want the Sleep functionality.
                        MikeH
                          I wonder how long it would take for a sleeping mac to drain a secondary battery in a battery isolation setup. My powerbook could sleep for many days before it's battery would drain.
                            I guess the calculations are pretty straight forward. Amps x hours = AmpHours... So if you drain .2 amps out of a 60 AH battery you would get approximatley 300 hours or 12.5 days....if the battery were new and fully charged. Your mileage will vary.
                            The battery isolation setup is a pretty good way to do this, however, the casual user probably doesn't want to hassle with putting one in.
                            200mA may be OK for the main battery, but I think it will eventually put a strain on it's useful life. I guess it will be a tradeoff.
                            MikeH
                              Anyway, I use my PC on standby, not hibernate, and I can leave it like that for days. I am sure the current draw on the Mac Mini while on standby will be similar to that of a powerbook, which can sleep for weeks without recharging.
                              In my experience sleep on the Mac is more similar to hibernate on the PC. Which makes the instantaneous wake from sleep even more impressive.
