Google Earth for OSX
  • Google Earth for OSX
    Google Earth for OSX is out:
    http://earth.google.com/
    I have yet to install my Mac Mini in my car, but I am taking a trip soon and plan on getting it temporarily setup to use google earth for GPS.
    More great news on the Mac mapping front!
    The Mercenary Missileer's 2000 Toyota 4Runner Highlander Edition
      Just tried it on my desktop Mac. Works great!
      Want to:
        Been running on my mini since I posted this.
        Of course works just the same as on the PC, all the same options.
        I have it caching my entire 3600 mile trip. (limited cell phone connection where I am traveling)
        So far so good, all the way from Austin to Vegas is cached and working offline so far.
        There is a great thread on automating GPS and google earth on a PC here:
        http://www.mp3car.com/vbulletin/showthread.php?t=63630
        Anyone willing to do a mac version?
          Anyone hear about google OS? Someone mentioned it at work today. Kind of on the same subject.
          http://www.kottke.org/04/04/google-operating-system
          okay not what i thought. oh well. sounds like a super online copmuter for everyone
          Um, I guess this is where you put something witty.WITTY
          My Web site, in the design stage. http://home.comcast.net/~cstrachn
          Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
            Check this out:
            http://www.cs.sunysb.edu/~tony/392/G...dDirector.html
            It's an App that reads GPS data and allows to you use applescript to pass it to a program.
            There is a beta for his OSX version.
            Any good scripters who can make this program write KMZ files?
            It looks like the software can output a HTML file, so it may be very easy.
            /Edit:
            I have found some good info, looks like it should be easy.
            Google has a tutorial on KML files here:
            http://www.keyhole.com/kml/kml_tut.html
            But basiclly here is a sample KML file:
            Code:
            <?xml version="1.0" encoding="UTF-8"?>
            <kml xmlns="http://earth.google.com/kml/2.0">
            <Placemark>
              <name>You are here</name>
              <LookAt>
                <longitude>-97.71000561814689</longitude>
                <latitude>30.42429421692663</latitude>
                <range>278.0278314144478</range>
                <tilt>-9.659668009047623e-012</tilt>
                <heading>0.01848385803939365</heading>
              </LookAt>
              <styleUrl>root://styles#default</styleUrl>
              <Point>
                <coordinates>-97.70987727305658,30.42409456391263,0</coordinates>
              </Point>
            </Placemark>
            </kml>
            It's XML, but as you can see inputing the GPS coordinants should be easy.
            But I don't know much about programming.
            I know mac's come with a powerfull scripting program that should be able to do this.
            Anyone here want to help out?
            This is all that is needed for google earth to track a point
            This puts you dead on to Hoover Dam.
            Code:
            <Placemark>
              <LookAt>
                <longitude>-114.738172</longitude>
                <latitude>36.016383</latitude>
                <range>360.34159687574</range>
                <tilt>60</tilt>
                <heading>0.000</heading>
              </LookAt>
            </Placemark>
            </kml>
            /Edit:
            Screw all that, I asked my co-worker here who GPS tracks his running and he said to check out:
            http://www.gpsbabel.org/
            It takes data from a GPS puck and outputs it directly to a Google Earth file.
              Here is the google earth mac forum I stumbled across it and thought it might intrest someone
              http://bbs.keyhole.com/ubb/postlist....d/SupportGEMac
                I saw somewhere that someone had created a program that makes kmz/kml files on the fly with data from a gps mouse. With a large cache of maps on your harddrive this sort of script could provide you with a decent in car mapping solution.
                Project completion 10%...own the mac mini. Currently writing lots of applescript. My for sale thread http://www.mp3car.com/vbulletin/showthread.php?t=72038
                  STI robot:
                  Check out the link I found and posted above:
                  My GPS mouse is on the way, I will post how it turns out.
                  You can cache a LOT of data.
                  I set my cache size to 2GB, made my route on GE, and set GE to follow the path. It travels slow enough to cache the entire route, and most of the surrounding areas along my route as it goes.
                  Several hours later, and 3000 virtual miles, I disconnected the mini from the net, shut down GE, and rebooted the mac.
                  Upon reboot GE retained all the data from the route, at least in spot checking.
                  I have a GPS mouse on the way and I will post how it went after my trip.
                    Originally posted by zapwizard
                    STI robot:
                    Not sure which one to download?
                      has anyone gotten the gps reading program to record files that GE can read yet? It seems easy. If we get this working we will have a nice mp3car.com homebrew GPS program. and with Dash_Run, we might be able to finally get something good goin here!
                      2005 Dodge Ram HEMI
                      http://www.cardomain.com/ride/2239451
                      15" LCD touchscreen
                      Mac Mini
                      6" Headrest monitors
                      Modded Xbox
                      5 PSone screens going in doors
                      And another 15" LCD!
                        I found a "cache proxy" program:
                        http://tlog.dehumanizer.com/2005/09/...th-with-squid/
                        What it does it run like a proxy and cache all data that you request. (can can do google earth)
                        So in theory you can go beyond the 2000MB cache on GE.
                          zapwizard what file do I download, those are all exe. files?
                            It looks like it has to be built from the sourcecode.
                            I don't have my USB puck yet so I haven't actualy tried it out yet.
                              How can we adjust the "Fly to" settings so it does not zoom out/pan so high/fast when going from one point to another that are far apart?
                              Pictures never lie.
                              Only Photoshop does.
