Front Row won't work
  • Front Row won't work
    I just got my mini today. It came with 10.4.3 loaded so i ran the updater. It updated to 10.4.5. I followed the instructions here:
    http://"http://www.macminicenter.com...ow_101:How-To"
    I install it but the when I get to the part after you run the installer it says you must log out. I click the button, it logs out, but won't log back in. It just sits at a blue screen. I restarted a couple of times and it only get's as far as the blue scree;it won't let me log in.
    So I rebooted in safe mode and restarted the computer. I was then able to log back in, but then I tried to install Front Row again and it just starts the cycle over.
    what instructions did you follow? the link didn't show up in your post
      Works
      This is what you want and it does work on 10.4.4, 10.4.5
      http://www.andrewescobar.com/archive...1/30/frontrow/
      HTH
      __________
      rgds, raceer
        I tried that one too...like 3 times. Same result. Do you think it has anything to do with the fact that I have 10.4.5 and not 10.4.4?
          i'm using front row on 10.4.5 with no problems. i'll try to look into it when i get some time.
          STATUS: Planning / In Progress / Completed
          COMPLETE: [*********] 100%
          CAR: '02 Mitsubishi Lancer OZ Rally
          SYSTEM: EPIA M10000
          GPS: HaiCOMM 303e GPS, Routis 2004
          DISPLAY: 7" Xenarc 700TSV
          POWER: OPUS PW-70a + ITPS Combo
          MISC: DVD, WLAN
            Well, that reminds me one thing: I installed FrontRow on my 10.4.4 following
            http://www.andrewescobar.com/archive...1/30/frontrow/ instruction. It was woking fine but I didn't actually use FrontRow a lot after that . Then, somepoint, I upgraded to 10.0.5 and that was fine too (writing from that PB right now). Oneday, suddenly I remember the FrontRow, I installed once but I found there is no sign of FrontRow any more. After installing the FronRow, I saw the new group for FrontRow under Preferences>Keyboard & Mouse>Keyboard Shortcuts and now that's gone too.
            Maybe due to 10.4.5 upgrade??
              did u follow the instructions exactly. also make sure to use the updated front row enabler and go in the exact order. u might want to try and trash all the stuff you originally installed and start from the beginning. i had problems when i updated my os and had to reinstall everything in front row
                Fixed it...used 10.4.4
                  you can probably update to 10.4.5 then. i just updated and haven't had any problems
                    Yeah...I just updated too and it still works. Weird.
                      guess thats what we get for using it on something its not made for
