Smart Install.....
  • Smart Install.....
    As some of you may know, i have a smart car, and was running a Mac INtel dual core in there.
    Well the time came to invest in the P1900 and Mac Pac.... So i ripped out the invertor, printed off the instructions, **** MYSELF, then started playing....
    Firstly, i have to say, there was no way i was gonna try and solder over the top of the R46 chip, so i ripped it straight off the board. Soldered a 3.3 resistor in place on top of the board as i didn't fancy hacking at the bottom of the board to solder underneath....
    I was surprised at how easy it was, even for someone that has never solered before, but i did buy the right solder iron 1st, and held it under a magnifier with thin long nosed pliers....
    The testing was simple, as i already had the power feeds available to me in the car from the invertor, so out comes the invertor, in goes the P1900 to test....
    BLOODY AMAZING, it worked 1st time on the settings i had already changed on the jumpers.....
    So now i know it works....
    It all came back out, so i can install it properly in a full day tomorrow....!
    I will update in the evening and will take photos along the course of putting it all together.
    Unfortunately, it will still be on the Kenwood screen, but it will be installed with all the cables ready to split to a vga monitor in a seperate location, and it will also be equiped with a 120Gb 2.5" external USB2 powered hard drive for the music and films....
    CLICK ME
    Smart Car due for completion beginning of march....
    Log with pictures to go online shortly after.
    It's now all in with all cables run for the vga screen as well....
    Think i may have a problem with sleep though, sometimes it goes into sleep and comes on with ignition, sometimes it shuts it right down, but i need to play with it when i have more time, as i haven't got any now for a couple of days...
    But i am happy with the progress, and am loaded the external drive with songs and movies as we speak...
    CLICK ME
      very discrete i like it.
      Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
        The idea was, that it is easily accessible, and the remote still works.... So i opted for there as it is a very easy fit, there is so much room in what is a very very small car.... Lol
        CLICK ME
          Would like to pick peoples brains as to how my install is working...
          Right, the P1900 is fine, no problem whatsoever.... EXCEPT when i have an external hd usb powered plugged in. If i have a mains powered hd or no hd at all it is no problem at all... When the usb powerd is plugged in, the power supply has a mind of it's own as to wether it sleeps or powers off.... I can't understand it, it is powered through the unit itself and not a hub, so there shouldn't be any problem....
          Apart from that, everything is perfect.....
          CLICK ME
            Changes in the USB state will cause the Mini to wake up. You need a hub that is powered ONLY. You don't want the hub to work in passive mode.
            I've had this problem before, you get out of the car and accidentally shuffle the mouse and it wakes up the Mini. When you get back, the car doesn't start.
            Want to:
              I don't think we are talking about the same problem....
              The mouse and keyboard are both bluetooth so no problem...!!!
              The External HD that i was using when i had everything pwered on an invertor is no problem, no external is no problem. An external USB powered hd but ONLY connected to the machine itself and NOT a hub makes the machine and power supply act in a very random way, ie when switching of the ignition it will sleep for about a minute then shut down or i'll switch the ignition on and it'll come out of sleep and shut down etc etc....
              Everything else is perfect, it's just this 1 problem....
              CLICK ME
                That is a nice install. Was the hole already there or did you cut it?
                Any plans to cut out the DVD slot and the IR receiver?
                  I've had issues with my desktop Mac using a KVM switch connected directly to the Mac. When I connected it to a powered hub, it worked much, much better. Supposedly, it has something to do with the Mac's sensitivity on the USB bus, but I couldn't guess what that might be. I've even had the Mac wake from sleep when I plugged a fan into the same outlet and turned it on!
                  If you have a powered hub, you might try connecting it to that.
                  Want to:
                    Right... I've tried the powered hub......!!!!! Still the same problem with the usb powered HD, even tried a different usb HD and the same problem....
                    Confused....
                    CLICK ME
                      You're sure that the powered hub doesn't switch to pulling power from the USB bus when you shut the car off? Some hubs do that.
                      If not, I can't imagine what it could be. I just know that state changes on the USB bus will cause the Mini to wake up.
                      Want to:
                        It is set to power fron the secondary source in the P1900 with NO POWER when in sleep..... So no.
                        It's not that that worries me, it's the differences in powering up when connected direct to the mac itself that is causing me the head ache as i don;t want or need the hub....
                        CLICK ME
                          MAC in Smart ( Mac Mini in Smart ForTwo )
                          I recently modified a Smart ForTwo with theme of Apple products. There are plenty number of pictures before and after the modifying process finished.
                          If you are interested in the car, check my MACinSmart car web page at www.MACinSmart.com .
                          If you need more information about my car, please let me, I will contact you as soon as possible.
                          Best regards,
                          Bahaeddin Nakiboglu
                          Gaziantep. TURKEY
                          www.MACinSmart.com
                          Inside of my car:
                          Main Unit :MAC Mini with Bluetooth and Airport
                          Monitor :XENARC 1020TSV - 10.2" VGA LCD Touchscreen Monitor
                          Front Speakers : MB Quart DSE 213 (2 piece, 2 adet)
                          Door Speakers : MB Quart RCE 164 (2 piece, 2 adet)
                          Back Speakers : MB Quart RCE 210 (2 piece, 2 adet)
                          Amplifiers : 1. amp. Rockford Fosgate Punch P450.4 2. amp. Rockford Fosgate Punch P250.2
                          Subwoofer : Rockford Fosgate P210S4
                          Signal Processor : Rockford Fosgate 3.sixty
                          Extras : USB Multimedia card reader with USB Expander
                          Griffin Powermate USB Multimedia Controller
                          USB Television Adaptor - Miglia TVMicro with Remote
                            Carpc plan=========90% -Never going to be finished!
                            Carpc parts==5% -Computer died
                            Carpc install==5% -Need to install computer
                            Carpc worklog-0% -Need to start that soon
