Using A Closed Powerbook WITHOUT an External Monitor?
  • Using A Closed Powerbook WITHOUT an External Monitor?
    In my car i have all the hookups I need and I want to use salling clicker on my Pocket PC phone as my controller (that means no keyboard, mouse, or monitor/touchscreen) i want to keep the amount of hardware at a minimum. Keeping the Powerbook closed is obviously easier to store, but i cant find any applications that make it possible to wake it (or keep it awake) with the lid closed. anybody know of anything that does the trick?
    my specs:
    osx 10.4.8
    867 mhz Powerpc G4
    thanks!
    not possible with software, hardware moddification to mke it work is the only way. which sucks.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
      Hack the switch is your only option.
      Want to:
        check what ehurtley says.. from another Mac forum:
        One thing people don't seem to realize is that for lid-closed mode to work, you MUST be plugged in to power.
        But, as long as you've got power and external video, it will wake up (and stay awake,) just fine from Bluetooth (and, on the MBP, using the Front Row remote as well.)
        I have gotten my MBP to wake up over Bluetooth from the Apple combo, as well as from a Salling Clicker-based Palm and cell phone, and from a third-party Bluetooth mouse. As long as you have 'Allow Bluetooth devices to wake this computer' checked in the Bluetooth preference pane, you should be fine.
        From the MacBook Pro User's Guide, pages 69-70:
        Using Your MacBook Pro with the Display Closed
        You can use your MacBook Pro with the display closed if the computer is connected to
        an external monitor, keyboard, and mouse.
        Important: To use your MacBook Pro with the display closed, the power adapter must
        be plugged into the MacBook Pro and a functioning power outlet.
        To operate your computer with an external monitor attached and the display closed:
        1 Connect a USB keyboard and mouse to your MacBook Pro.
        2 Connect the power adapter to the MacBook Pro and a power outlet. Check that the power adapter light is on.
        3 Close the MacBook Pro display to put the computer to sleep.
        4 Follow the steps in the previous section to connect your MacBook Pro to an external display.
        5 Wait a few seconds and then press any key on the external keyboard to wake the MacBook Pro.
        It also mentions that the Apple Remote can wake up the MacBook Pro, but while it doesn't specifically mention that Bluetooth devices will wake it up for lid-closed operation, I can confirm from personal testing that it does work.
        Well maybe you have to connect an external monitor... but it's the thing you dont' wanto to do...
        My suggestion is to buy a low cost, non touch car VGA monitor and connect it to your MacBook pro or powerbook... or just a Car TV receiver with composite input may work...
          wow cool. i wonder if it would work on older laptops as well. good to know, good find.
            PowerBook G3 and G4 (Titanium) could be used with lid closed.
            I do not think it is necessary to connect the actual display to the PowerBook. DVI->VGA display alone might do the trick.
              Sweet! Good to know.
              Want to:
                do you mean using the adapter that came with it to fool the laptop?
                  Yes
                    These may, or may not, help you:
                    http://www.alxsoft.com/mac/sleepless.html
                    http://semaja2.net/insomniaxinfo/
                      i took jirkas advice and just connected the adapter and it worked like a charm
                        You can try this software called Sleepless:
                        Powerbooks can run fine closed, just normally they're also attached to monitors and keyboards.
                          Synthetikid,
                          Iíve tried a small DVI to VGA adapter and a DVI cable on my PowerBook G4. Neither option worked. Could you tell us more about the method you used to fake your computer to not go to sleep when operating in closed / clamshell mode without an external display? Iím desperate. Thanks.
                          Hand123
                            I doubt it. His last post was 4 years ago.
                            Want to:
