Shutdown controller software - RR Style
  • Shutdown controller software - RR Style
    Here are a new release of my Shutdown controller software, you can get it here:
    http://ormkarr.cjb.net/downloads/SDC.rar
    It monitors pin 4 and 8 and takes different actions to the shutdown sequence, please post your questions here.
    I also made a circuit that integrates with the software based on a picprocessor to control my computer power on and also monitor it if it hangs and reboots it, if someone is interested I could post more info on that...
    Please do!
      Very interesting!
      Please, post Pic hardware (all infos,schematic,etc...)
      Mauri
        Here is a picture of a prototype, based on PIC 12F629:
        Click image for larger version
Name:	SDC Circiut.JPG
        Inputs:
        Ignition key
        Computer comport
        Outputs:
        Computer power switch
        Computer reset switch
        Power relay, to control Inverter
        Amplifier
        Computer comport
        Features:
        Turn ignition key on and Power relay to inverter is activated, after 2 secs the power button is pressed on. Now it waits for signal from comport, if it has not been recieved in 4 minutes it pushes reset button. If it recieves signal from comport it activates amplifiers.
        Turn off ignition key it pauses RR (optional) and wait for user defined time to go into shutdown sequence. It also brings up a menu so the user can choose what he wants to do when the ignition is off, for example stay on for X amount of seconds, go into standby/hibernation directly.
          Here is a simplified schema
