Start application
  • Start application
    Does anyone know how to start an application, for example gps proxy when windows start? I search and tried placing a shortcut in the startup folder but it only starts the app, it is not started. What I mean is if we place a winamp shortcut in startup folder it will start winamp but it does not play any songs. Have to put a play list in and songs will be played. How can I do this for GPS proxy?
    autoit perhaps.
    1.9in x 2.9in -- 47mm x 73mm
      I'll try....Thanks
        Usually autoit can help, but in some cases it cant. In that case, you might need to right an application using API calls and put that alond with the gps program in the startup folder...
          I have autoit installed but don't know how to program.....Any hint I could start with? BTW what is API?
            API is the system windows uses for everything. When you right click some program in the task bar, that is a command. When you click close from the menu that is a command.
            So you need to find the handle of the window, which is a 32bit int (obviously only on 32bit systems), and then the command like "SendMessage" from the user32.dll, and then the argument of "Push button".
            Can get really complicated.
              It will be easier using only autoit?
                Easier yes.
                There are quite a few autoit scripts floating around the forum, and you might be able to learn by example. Basically if there is a keyboard shortcut to do what you want it to do, then really easy. If there is a menu item, then easier. If not, then you are pretty much SOL.
                  Thanks for all the reply and info...I'll try it out
                    Originally posted by 2k1Toaster View Post
                    Easier yes.
                    Tried it and it worked.....just like you said its easy. Only 2 lines.
                    Anyone interested can copy here....auto start for GPS Proxy
