no video in roadrunner
  • no video in roadrunner
    Well I just reinstalled xp on my carputer, then installed roadrunner, winamp and windvd, and k-lite codec pack and loaded all my music and movies back on and now I'm having a little problem. When I try to play any videos the audio plays but not the video, how do I fix this, thanks.
    can you reccomend any codec packs, because for some reason k-lite has failed me
      I'm not sure which one I installed, it's one I downloaded ages ago and have it one my server at home.
      I'll try and look later today if you haven't found anything by then.
        I've just started a fresh install of xp for my carputer project so I too would like to know what is the best codec players to install.
        If I'm not mistaken, I think when I installed the newest win.media player on my other computer, it updated a lot of codecs.
          ffdshow tryouts did the trick for me.
            I have a similar issue - just wiped my machine and re-installed RR.
            The videos used to work before but don't now - they work when i play them directly in media player classic but not in RR - but they don't even start so i know its a different issue.
            I installed the Kodec Pack and winamp and im using TinyXP with minilogin if that makes any difference ?
              Interesting........
              I'm having similar issue, but it seems to only be in lsx void 3.0 skin..............all other skins work and mpc will play videos when run stand alone.
              Which skin are you running?
              Leonardo Da Vinci
                Im using a slightly edited standard skin - the one that comes with the RR install
                  check the rr bug tracker..latest rr had a problem with video
                  guino fixed it yesterday..redownload RR
                    Excellent - i only downloaded it yesterday but was possibly before he fixed it - thanks for the info , ill check when i get home
                      Ok , just tried that and it seems that i have the latest install ... the thing is it works find on media player classic directly , but they dont even start to play when in RR
                        Same issue still here too.............
                        I'm getting mci errors in the debug log.
                        Anyone?
                        Leonardo Da Vinci
                          there are 2 ways of playing videos in RR
                          1. selecting built in video
                          2. selecting MPC
                          try the 2nd athough it is not as integrated as the 1st but it might work for you.
                          as for the 2nd i really do not know what it needs for it to work..directshow??! maybe guino could enlighten us more
                            Well, I have gotten mpc to work, but it eventually go "tits-up" also. At first I thought it was something in the void 3.0 skin, but now..............not so sure...........
                            Leonardo Da Vinci
