Iguidance mod question
  • Iguidance mod question
    how can I make iguidance not display the bottom info bar one that displays ETA REM DST SPD
    I would rather display this information in my skin and be able to make the IG display a small on other screens.
    Any mods out there that can be done.
    New Age Garmin - Skin for RR
    I checked through reshack and cant find the menu or info. Any help would be appreciated.
      I haven't find a way to do it with resource hacker. But if you are intended to do it with RoadRunner, RR has a redraw function that can trim the bottom part. If you look at RR's code, the function is in API module. I forgot the function name but that one is easy to find because it has a portion to trim IG window. That function take in 4 parameter for size. I think I add or subtract 20 pixels to have it trim to what it is now. Instead of 20, just add/subtract more to trim the bottom. Look around and you will find it.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
