How to get millage using GPS?
  • How to get millage using GPS?
    hi! Im newbie here.... im using holux 216 and nRoute. So my question, how to extract the odometer in the nRoute??? can anybody help me?
    there are plugins you can get that will do this, what front end you using? if you use road runner with the latest idrive (by enforcer) skin that has the plugin already done
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
      mmm..im using road runner...but the problem is...im using 'external gps' in the gps setting under road runner...so can i still get mileage data???
        what nav you using? i think it designed for destinator
        CarPuter Progress:
          mmm..im noob here
          this is my current gps setting...
          -mapsource
          -garmin map
          -nroute
          -gpsgate 2.5
          i set nroute as external gps in rr....somebody..help me....
            you should intercept the NEMA data the GPS is sending, especially the $GPRMC command.
            Also you should use some kind of COM port splitter software.
            /Me.
              /Me.
              ok...how to intercept?
              com port splitter is it like "virtual Serial Port" or VSPD ?
                gpsgate is a com port splitter
                id be interested if this could be down too for nroute
                i have same set up as budaknakal too
