Andi-Mp Alpha 1 Release
  • Andi-Mp Alpha 1 Release
    Guys Check this out I have been working on it for a while, It is now where near ready. But I think it has promise.
    any way unpack the zip, register remoteplayerctrl.dll and it should work, Oh and you need dotnet 2.0. and for navigation you need IGuidance 3.0, Windows Media Player 10+ is required for music.
    Oh and dont be shy, I am open to all criticism
    Sorry the Images are so Late --
    LilliPut Housing Complete
    MAP POINT WITH EARTH MATE
    TV/FM/XM
    1.7 GHZ 500MB RAM , 60 GB HD
    SLIM LINE DVD DRIVE
    FRONT END: CUSTOM A.N.D.I. - M.P
    Anybody want to help with this - I am willing to share source
    TV/FM/XM
    SLIM LINE DVD DRIVE
      AndiMp Front End Alpha
      Well I guess since no has posted anything, I should scrub this project and move on !
      TV/FM/XM
      SLIM LINE DVD DRIVE
        i wouldnt scrap the project just yet, i was interested in trying it but was having trouble getting the remoteplayerctrl.dll to register
        FocusPC Stat:
        [~~~~~~~~~-] 95% Done
        FreeICE | FreeWay | iGuidance | Paper and pencil
        FocusPC
        FreeWay Skins
          Sorry, here are the files , you need the Visual C++ Redist, and also an updated copy of AndiFull.exe, You need to run vcredist_x86.exe and then remoteplayerctrl.dll should work, also replace the AndiFull.exe with the one in the update.
          Let me know how it goes
          TV/FM/XM
          SLIM LINE DVD DRIVE
            The Good, The Bad and the Ugly
            So here comes my review . As you said I won't be shy. So after installing the update running the exe and registering the dll. I loaded up the program. After that well uhm it went orange. That's it. I was wondering where are the main menu buttons. Is it just my pc or is the program freaking.
            Still I was able to give you some information. I would lose the orange color but because it is skinnable don't worry about it. I was able to see when I was looking at the skin files that it would be pretty easy to make a skin. I tried changing the forecolor in the settings file but had zero result so I just click the orange buttons and waited for something to happen. Nice to keep in mind the text on the top which told me what number was playing did appear. Also the buttons on the main menu where a bit large the fell out off the box you created for them (that square thingy :P)
            So the first button I clicked was the (I guess Jukebox button). It looked clean and located the My Music directory nicely. Downside because I am from holland I do not have a My Music directory (I don't have a My Video directory either). But because some program created it it was able to load. Could not see any names but could see images. Worked nicely and clean interface.
            As for the second button (video) it could not find my video directory because I have a dutch version of windows. Created one and it worked. Looks nice just as the music player.
            I do not have nav installed on my main pc just like xm so could not test that. Would like to test it some more when the buttons are fixed so I can see what I am clicking. Keep up the good work.
            So a small list of things to fix:
            - Button texts
            - My Music (Dutch: Mijn Muziek)
            - My Video (Dutch: Mijn Video's)
            - Doesn't load very quickly when booting why ???
            As for the skinnability and all nice work keep it up.
            With Kind Regards,
            MOnline
            Check out My Custom Frontend
              Thanks for checking things out. I have a couple of questions..
              1) What was the resolution you were using, the program only works with 800x600
              2) What CPU, RAM does your Test PC Contain.
              3) Do you have your music files loaded in a Windows Media Player Library, if not then that is why you did not get a list of albums.. in the Jukbox.
              Again thank you so much for your help, I will try to fix a few things then post again if dont mind looking at it once more.
              TV/FM/XM
              SLIM LINE DVD DRIVE
                He,
                Well I do have music files loaded in windows media player and I can see the albums. But I can not access the video menu because I have a dutch version of windows xp. This means that the path c:/documents and settings/username/My Music and c:/documents and settings/username/My Video's do not exist. They are called Mijn Muziek and Mijn Video's.
                As for my system specs:
                Windows XP Pro (Dutch)
                Ram: 2 Gb
                Harddisk: 250 GB
                Processor: AMD Athlon (32 bit so default) 3000+ (equals 3 ghz)
                My screen resolution was 1440 x 900 but I just changed it to 800 x 600 and it did the same thing. Here's a picture of it running
                O and please do one more thing for me. Let me be able to select if the program can hide my start bar.
                Don't mind testing it out when you made changes.
                With kind regards,
                FG van Zeelst
                PS
                What did you build this program in C++, Visual Basic, Visual Basic.net ?
                  i get a few different error messages
                  first one comes up right after Andi loads:
                  and heres the error it gave:
                  Code:
                  See the end of this message for details on invoking
                  just-in-time (JIT) debugging instead of this dialog box.
                  ************** Exception Text **************
                  System.IO.FileNotFoundException: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
                     at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
                     at System.Windows.Forms.AxHost.CreateWithoutLicense(Guid clsid)
                     at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
                     at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
                     at System.Windows.Forms.AxHost.CreateInstance()
                     at System.Windows.Forms.AxHost.GetOcxCreate()
                     at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
                     at System.Windows.Forms.AxHost.CreateHandle()
                     at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
                     at System.Windows.Forms.Control.CreateControl()
                     at System.Windows.Forms.Control.ControlCollection.Add(Control value)
                     at System.Windows.Forms.Form.ControlCollection.Add(Control value)
                     at AndiFull.frmbase.InitSkin()
                     at AndiFull.frmbase.frmBase_Activated(Object sender, EventArgs e)
                     at System.Windows.Forms.Form.OnActivated(EventArgs e)
                     at System.Windows.Forms.Form.set_Active(Boolean value)
                     at System.Windows.Forms.Form.WmActivate(Message& m)
                     at System.Windows.Forms.Form.WndProc(Message& m)
                     at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
                     at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
                     at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
                  ************** Loaded Assemblies **************
                  mscorlib
                      Assembly Version: 2.0.0.0
                      Win32 Version: 2.0.50727.42 (RTM.050727-4200)
                      CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
                  AndiFull
                      Assembly Version: 1.0.0.0
                      Win32 Version: 1.0.0.0
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiFull.exe
                  System.Xml
                      CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
                  System
                      CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
                      CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
                  System.Drawing
                      CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
                  Interop.WMPLib
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.WMPLib.DLL
                  Interop.SpeechLib
                      Assembly Version: 5.0.0.0
                      Win32 Version: 5.0.0.0
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.SpeechLib.DLL
                  AxInterop.RemotePlayerCtrlLib
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.RemotePlayerCtrlLib.DLL
                  WaveLibMixer
                      Assembly Version: 1.0.2834.38040
                      Win32 Version: 1.0.2834.38040
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/WaveLibMixer.DLL
                  AxInterop.WMPLib
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AxInterop.WMPLib.DLL
                  AndiMpControls
                      Assembly Version: 1.0.2836.36400
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiMpControls.DLL
                  AndiIgHost
                      Assembly Version: 1.0.2836.34016
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/AndiIgHost.DLL
                  ************** JIT Debugging **************
                  To enable just-in-time (JIT) debugging, the .config file for this
                  application or computer (machine.config) must have the
                  jitDebugging value set in the system.windows.forms section.
                  The application must also be compiled with debugging
                  enabled.
                  For example:
                  <configuration>
                      <system.windows.forms jitDebugging="true" />
                  </configuration>
                  When JIT debugging is enabled, any unhandled exception
                  will be sent to the JIT debugger registered on the computer
                  rather than be handled by this dialog box.
                  second one comes up when i click on a album under jukebox:
                  Code:
                  Method 'OpenFile' cannot be invoked at this time.
                  mscorlib
                  AndiFull
                  System.Xml
                  System
                  System.Drawing
                  Interop.WMPLib
                  Interop.SpeechLib
                  WaveLibMixer
                  AxInterop.WMPLib
                  AndiMpControls
                  AndiIgHost
                      CodeBase: file:///C:/Documents%20and%20Settings/Maddash/Desktop/Car%20Stereo%20betas/AndiFullupdate/Interop.RemotePlayerCtrlLib.DLL
                  System.Configuration
                      CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
                  enabled.
                  For example:
                  <configuration>
                  </configuration>
                  i also get a error message every time i click on something
                  FocusPC Stat:
                  FocusPC
                  FreeWay Skins
                    MOline Thanks, I found why you dont get any text, I think it is becacuse the language is in english, I will try to make the program work with other lanuages
                    Originally posted by MOnline View Post
                    He,
                    Ram: 2 Gb
                    Harddisk: 250 GB
                    With kind regards,
                    FG van Zeelst
                    PS
                    TV/FM/XM
                    SLIM LINE DVD DRIVE
                      Did you register remoteplayerctrl.dll ?
                      Code:
                      mscorlib
                      AndiFull
                      System.Xml
                      System
                      System.Drawing
                      Interop.WMPLib
                      Interop.SpeechLib
                      WaveLibMixer
                      AxInterop.WMPLib
                      AndiMpControls
                      AndiIgHost
                      enabled.
                      For example:
                      <configuration>
                      </configuration>
                      Code:
                      mscorlib
                      AndiFull
                      System.Xml
                      System
                      System.Drawing
                      Interop.WMPLib
                      Interop.SpeechLib
                      WaveLibMixer
                      AxInterop.WMPLib
                      AndiMpControls
                      AndiIgHost
                      enabled.
                      For example:
                      <configuration>
                      </configuration>
                      TV/FM/XM
                      SLIM LINE DVD DRIVE
                        I tried it on my laptop (resolution 1440 by 800) and it worked nicely (at least the buttons show up). I will review it later today. But still it would be good if it worked on all systems .
                        With kind regards,
                        FG van Zeelst
                          In the next couple of days, I will make work with other languages and post the updated EXE..
                          Also I have Skin Maker Program, you think I should post that ..
                          With kind regards,
                          FG van Zeelst
                          TV/FM/XM
                          SLIM LINE DVD DRIVE
                            You should definitly post the skin maker program. Maybe I will even try to create a nice one for you just for fun (not that good of a skinner) but still.
                            About the languages you should add a default one just for people that use foreign languages.
                            With kind regards,
                            FG van Zeelst
                              Update
                              Ok here is an update, corrected the bug to allow other languages besides english, also add settings screen, which will allow you to turn on and off some of the options
                              TV/FM/XM
                              SLIM LINE DVD DRIVE
