Can´t get DirectX to work
  • Can´t get DirectX to work
    I have a VIA EPIA SP13000 mothercard.
    I am trying to get Streetdeck to work(the trial version) for testing it out.
    But i wont. And I gues it´s because the DirectX not working to 100%.
    This is what I get when trying dxdiax.
    Does any one know if it is supporting DirectX and where to find the drivers?
    I have tryed two at the via homepage with no luck.
    System Information
    Time of this report: 10/19/2007, 14:33:48
    Machine name: CARPC
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
    Language: Swedish (Regional Setting: Swedish)
    System Manufacturer: CN400_
    System Model: AWRDACPI
    BIOS: Phoenix - AwardBIOS v6.00PG
    Processor: VIA Nehemiah, MMX, ~1.3GHz
    Memory: 448MB RAM
    Page File: 133MB used, 924MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name:
    Manufacturer:
    Chip type:
    DAC type:
    Device Key: Enum\
    Display Memory: n/a
    Current Mode: 1440 x 900 (16 bit) (42Hz)
    Monitor:
    Monitor Max Res:
    Driver Name: RDPDD.dll
    Driver Version: 5.01.2600.2180 (English)
    DDI Version: unknown
    Driver Attributes: Final Retail
    Driver Date/Size: 8/4/2004 01:35:08, 92168 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: n/a
    VDD: Saknas
    Mini VDD:
    Mini VDD Date: n/a, 0 bytes
    Device Identifier: {D7B70EE0-4340-11CF-346B-282AAEC2C835}
    Vendor ID: 0x0000
    Device ID: 0x0000
    SubSys ID: 0x00000000
    Revision ID: 0x0000
    Revision ID: 0x0000
    Video Accel:
    Deinterlace Caps: n/a
    Registry: OK
    DDraw Status: Not Available
    D3D Status: Not Available
    AGP Status: Not Available
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    Sound Devices
    Description: Ljuddrivrutin för Microsoft RDP (emulerad)
    Default Sound Playback: Yes
    Default Voice Playback: No
    Hardware ID:
    Manufacturer ID: 1
    Product ID: 24
    Type: Emulerad
    Driver Name:
    Driver Version:
    Driver Attributes:
    WHQL Logo'd:
    Date and Size:
    Other Files:
    Driver Provider:
    HW Accel Level: Full
    Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Registry: OK
    Sound Test Result: Not run
    Sound Capture Devices
    DirectMusic
    DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
    DLS Version: 1.00.0016.0002
    Acceleration: n/a
    Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
    Vinyl AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
    Microsoft MIDI Mapper [Emulerat], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Registry: OK
    DirectInput Devices
    Device Name: Mus
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Tangentbord
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Poll w/ Interrupt: No
    Registry: OK
    USB Devices
    + USB-rotnav (hub)
    | Vendor/Product ID: 0x1106, 0x3038
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
    | Driver: usbd.sys, 9/28/2001 16:00:00, 4736 bytes
    +-+ USB Touchscreen Controller(Universal)
    | | Vendor/Product ID: 0x0EEF, 0x0001
    | | Matching Device ID: usb\vid_0eef&pid_0001
    | | Service: xtouch
    | | Driver: xtouch.sys, 10/15/2007 08:22:51, 81024 bytes
    Gameport Devices
    PS/2 Devices
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: termdd.sys, 8/4/2004 01:35:06, 40840 bytes
    | Driver: kbdclass.sys, 8/4/2004 01:18:46, 24832 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: mouclass.sys, 8/4/2004 01:46:42, 23296 bytes
    DirectPlay Service Providers
    DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
    DirectPlay Test Result: Not run
    Registry: OK
    DirectPlay Adapters
    DirectPlay8 Serial Service Provider: COM1
    DirectPlay8 Serial Service Provider: COM2
    DirectPlay8 TCP/IP Service Provider: Anslutning till lokalt nätverk 2 - IPv4 -
    DirectPlay Voice Codecs
    Voxware VR12 1,4 kbit/s
    Voxware SC06 6,4 kbit/s
    Voxware SC03 3,2 kbit/s
    MS-PCM 64 kbit/s
    MS-ADPCM 32,8 kbit/s
    Microsoft GSM 6.10 13 kbit/s
    TrueSpeech(TM) 8,6 kbit/s
    DirectPlay Lobbyable Apps
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 17.8 GB
    Total Space: 20.0 GB
    File System: NTFS
    Model: FUJITSU MHT2080AT
    Drive: D:
    Free Space: 55.7 GB
    Total Space: 5.1 GB
    File System: NTFS
    Drive: E:
    Model: MAT****A CD-RW CW-8124
    Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Swedish), 8/3/2004 22:59:54, 49536 bytes
    System Devices
    Name: VIA CPU to AGP Controller
    Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&08
    Driver: n/a
    Name: PCI standard host CPU bridge
    Device ID: PCI\VEN_1106&DEV_7259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&07
    Driver: n/a
    Device ID: PCI\VEN_1106&DEV_4259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&04
    Driver: n/a
    Device ID: PCI\VEN_1106&DEV_3259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&03
    Driver: n/a
    Name: PCI standard ISA bridge
    Device ID: PCI\VEN_1106&DEV_3227&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&88
    Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Swedish), 9/28/2001 16:00:00, 36096 bytes
    Device ID: PCI\VEN_1106&DEV_3149&SUBSYS_AA011106&REV_80\3&13C 0B0C5&0&78
    Driver: n/a
    Name: VIA/S3G UniChrome Pro IGP
    Device ID: PCI\VEN_1106&DEV_3118&SUBSYS_31181106&REV_02\4&8CA 73A7&0&0008
    Driver: C:\WINDOWS\system32\DRIVERS\vtmini.sys, 6.14.0010.0342 (English), 10/19/2007 14:18:32, 269056 bytes
    Driver: C:\WINDOWS\system32\vtdisp.dll, 6.14.0010.0342 (English), 10/19/2007 14:18:27, 3523072 bytes
    Driver: C:\WINDOWS\system32\vticd.dll, 6.14.0010.0342 (English), 10/19/2007 14:18:31, 1888256 bytes
    Driver: C:\WINDOWS\help\VTDspChs.hlp, 10/19/2007 14:18:27, 21467 bytes
    Driver: C:\WINDOWS\help\VTDspCht.hlp, 10/19/2007 14:18:27, 22749 bytes
    Driver: C:\WINDOWS\help\VTDspJpn.hlp, 10/19/2007 14:18:27, 22872 bytes
    Driver: C:\WINDOWS\help\VTDspKor.hlp, 10/19/2007 14:18:28, 24036 bytes
    Driver: C:\WINDOWS\help\VTDspWst.hlp, 10/19/2007 14:18:29, 233926 bytes
    Driver: C:\WINDOWS\help\VTDspTha.hlp, 10/19/2007 14:18:28, 19340 bytes
    Driver: C:\WINDOWS\help\VTDspWs2.hlp, 10/19/2007 14:18:28, 170362 bytes
    Driver: C:\WINDOWS\help\VTGm2WST.hlp, 10/19/2007 14:18:30, 142400 bytes
    Driver: C:\WINDOWS\help\VTGm2CHS.hlp, 10/19/2007 14:18:29, 17543 bytes
    Driver: C:\WINDOWS\help\VTGm2CHT.hlp, 10/19/2007 14:18:29, 17421 bytes
    Driver: C:\WINDOWS\help\VTGm2JPN.hlp, 10/19/2007 14:18:29, 16609 bytes
    Driver: C:\WINDOWS\help\VTGm2KOR.hlp, 10/19/2007 14:18:30, 19205 bytes
    Driver: C:\WINDOWS\help\VTGm2Tha.hlp, 10/19/2007 14:18:30, 18491 bytes
    Driver: C:\WINDOWS\help\VTGm2Ws2.hlp, 10/19/2007 14:18:30, 104672 bytes
    Driver: C:\WINDOWS\help\VTin2wst.hlp, 10/19/2007 14:18:32, 61309 bytes
    Driver: C:\WINDOWS\help\VTin2chs.hlp, 10/19/2007 14:18:31, 9303 bytes
    Driver: C:\WINDOWS\help\VTin2cht.hlp, 10/19/2007 14:18:31, 9760 bytes
    Driver: C:\WINDOWS\help\VTin2jpn.hlp, 10/19/2007 14:18:31, 9582 bytes
    Driver: C:\WINDOWS\help\VTin2kor.hlp, 10/19/2007 14:18:32, 10225 bytes
    Driver: C:\WINDOWS\help\VTIn2Tha.hlp, 10/19/2007 14:18:32, 8070 bytes
    Driver: C:\WINDOWS\help\VTin2ws2.hlp, 10/19/2007 14:18:32, 49147 bytes
    Driver: C:\WINDOWS\help\VTovlwst.hlp, 10/19/2007 14:18:34, 72478 bytes
    Driver: C:\WINDOWS\help\VTovlchs.hlp, 10/19/2007 14:18:33, 10567 bytes
    Driver: C:\WINDOWS\help\VTovlcht.hlp, 10/19/2007 14:18:33, 10523 bytes
    Driver: C:\WINDOWS\help\VTovljpn.hlp, 10/19/2007 14:18:33, 10504 bytes
    Driver: C:\WINDOWS\help\VTovlkor.hlp, 10/19/2007 14:18:33, 11349 bytes
    Driver: C:\WINDOWS\help\VTOvlTha.hlp, 10/19/2007 14:18:34, 8686 bytes
    Driver: C:\WINDOWS\help\VTOvlWs2.hlp, 10/19/2007 14:18:34, 50989 bytes
    Driver: C:\WINDOWS\system32\VTDisply.cfg, 10/19/2007 14:18:27, 63489 bytes
    Driver: C:\WINDOWS\system32\VTDispl2.cfg, 10/19/2007 14:18:27, 56619 bytes
    Driver: C:\WINDOWS\system32\VTDispl3.cfg, 10/19/2007 14:18:27, 52037 bytes
    Driver: C:\WINDOWS\system32\VTDisply.dll, 2.01.0008.1018 (English), 10/19/2007 14:18:27, 651264 bytes
    Driver: C:\WINDOWS\system32\VTGamma2.dll, 2.00.0037.0619 (English), 10/19/2007 14:18:29, 462848 bytes
    Driver: C:\WINDOWS\system32\VTGamma2.cfg, 10/19/2007 14:18:29, 50215 bytes
    Driver: C:\WINDOWS\system32\VTGama_2.cfg, 10/19/2007 14:18:29, 36546 bytes
    Driver: C:\WINDOWS\system32\VTInfo2.dll, 2.00.0043.0619 (English), 10/19/2007 14:18:32, 327680 bytes
    Driver: C:\WINDOWS\system32\VTInfo2.cfg, 10/19/2007 14:18:32, 44076 bytes
    Driver: C:\WINDOWS\system32\VTovrlay.dll, 2.00.0041.0517 (English), 10/19/2007 14:18:34, 593920 bytes
    Driver: C:\WINDOWS\system32\VTovrlay.cfg, 10/19/2007 14:18:34, 59327 bytes
    Driver: C:\WINDOWS\system32\VTOvrly2.cfg, 10/19/2007 14:18:34, 34375 bytes
    Driver: C:\WINDOWS\system32\VTTimer.exe, 2.00.0008.0921 (English), 10/19/2007 14:18:34, 53248 bytes
    Driver: C:\WINDOWS\system32\VModes.exe, 1.00.0004.1027 (English), 10/19/2007 14:18:24, 28672 bytes
    Driver: C:\WINDOWS\system32\VTCfg3d.dll, 2.00.0047.0719 (English), 10/19/2007 14:18:24, 417792 bytes
    Driver: C:\WINDOWS\system32\VTCfg3d.cfg, 10/19/2007 14:18:24, 43390 bytes
    Driver: C:\WINDOWS\help\VTcfgwst.hlp, 10/19/2007 14:18:26, 109209 bytes
    Driver: C:\WINDOWS\help\VTCfgChs.hlp, 10/19/2007 14:18:25, 13008 bytes
    Driver: C:\WINDOWS\help\VTCfgCht.hlp, 10/19/2007 14:18:25, 13271 bytes
    Driver: C:\WINDOWS\help\VTCfgJpn.hlp, 10/19/2007 14:18:25, 10649 bytes
    Driver: C:\WINDOWS\help\VTCfgKor.hlp, 10/19/2007 14:18:26, 13191 bytes
    Driver: C:\WINDOWS\help\VTCfgTha.hlp, 10/19/2007 14:18:26, 9257 bytes
    Driver: C:\WINDOWS\help\VTCfgWs2.hlp, 10/19/2007 14:18:26, 77945 bytes
    Driver: C:\WINDOWS\system32\VTTrayp.exe, 2.00.0057.0927 (English), 10/19/2007 14:18:36, 176128 bytes
    Driver: C:\WINDOWS\system32\VTTrayp.cfg, 10/19/2007 14:18:36, 51124 bytes
    Driver: C:\WINDOWS\system32\VTTrayP2.cfg, 10/19/2007 14:18:36, 37162 bytes
    Driver: C:\WINDOWS\help\VTtpwst.hlp, 10/19/2007 14:18:36, 105855 bytes
    Driver: C:\WINDOWS\help\VTTPChs.hlp, 10/19/2007 14:18:35, 14728 bytes
    Driver: C:\WINDOWS\help\VTTPCht.hlp, 10/19/2007 14:18:35, 14410 bytes
    Driver: C:\WINDOWS\help\VTTPJpn.hlp, 10/19/2007 14:18:35, 13602 bytes
    Driver: C:\WINDOWS\help\VTTPKor.hlp, 10/19/2007 14:18:36, 16213 bytes
    Driver: C:\WINDOWS\help\VTTPTha.hlp, 10/19/2007 14:18:36, 11042 bytes
    Driver: C:\WINDOWS\help\VTTPWs2.hlp, 10/19/2007 14:18:36, 88693 bytes
    Name: VIA USB Enhanced Host Controller
    Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_31041106&REV_86\3&13C 0B0C5&0&84
    Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
    Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
    Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Swedish), 8/4/2004 03:34:02, 75264 bytes
    Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
    Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 01:33:38, 7168 bytes
    Name: VIA PCI 10/100Mb Fast Ethernet Adapter
    Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_01021106&REV_78\3&13C 0B0C5&0&90
    Driver: C:\WINDOWS\system32\DRIVERS\fetnd5.sys, 2.66.0000.0290 (English), 8/17/2001 22:13:08, 27165 bytes
    Name: Vinyl AC'97 Codec Combo Driver (WDM)
    Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_AA011106&REV_60\3&13C 0B0C5&0&8D
    Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (Swedish), 8/4/2004 01:33:42, 4096 bytes
    Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (Swedish), 8/4/2004 01:34:54, 130048 bytes
    Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (Swedish), 8/3/2004 23:15:22, 140928 bytes
    Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
    Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
    Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (Swedish), 8/3/2004 23:08:04, 48640 bytes
    Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:34:56, 23552 bytes
    Driver: C:\WINDOWS\system32\drivers\vinyl97.sys, 6.14.0001.4070 (English), 9/6/2004 10:01:56, 161536 bytes
    Name: VIA OHCI-kompatibel IEEE 1394-värdstyrenhet
    Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_30441106&REV_80\3&13C 0B0C5&0&68
    Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:10, 61056 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:08, 53248 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:46:42, 61824 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:46:42, 60800 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 23:46:40, 6400 bytes
    Name: VIA Rev 5 or later USB Universal Host Controller
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&83
    Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&82
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&81
    Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_AA011106&REV_81\3&13C 0B0C5&0&80
    Device ID: PCI\VEN_1106&DEV_2259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&02
    Driver: n/a
    Device ID: PCI\VEN_1106&DEV_1259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&01
    Driver: n/a
    Name: VIA Bus Master IDE Controller
    Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_AA011106&REV_06\3&13C 0B0C5&0&79
    Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 8/3/2004 22:59:44, 5376 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Swedish), 8/3/2004 22:59:42, 25088 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
    Device ID: PCI\VEN_1106&DEV_0259&SUBSYS_00000000&REV_00\3&13C 0B0C5&0&00
    Driver: n/a
    Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
    Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\3&13C 0B0C5&0&A0
    Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/4/2004 00:31:34, 20992 bytes
    DirectX Components
    ddraw.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:32 266240 bytes
    ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 27136 bytes
    dxapi.sys: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:32 1179648 bytes
    d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 1689088 bytes
    d3dim.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 436224 bytes
    d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:32 825344 bytes
    d3dramp.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 590336 bytes
    d3drm.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 350208 bytes
    d3dxof.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 47616 bytes
    d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 34816 bytes
    dplay.dll: 5.00.2134.0001 Swedish Final Retail 9/28/2001 16:00:00 33040 bytes
    dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 229888 bytes
    dpmodemx.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 23552 bytes
    dpwsock.dll: 5.00.2134.0001 English Final Retail 9/28/2001 16:00:00 42768 bytes
    dpwsockx.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 57344 bytes
    dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:34:18 30208 bytes
    dpnsvr.exe: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:18 17920 bytes
    dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 375296 bytes
    dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:30:34 3584 bytes
    dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:30:34 3584 bytes
    dpvoice.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 212480 bytes
    dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 01:34:18 83456 bytes
    dpvvox.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 116736 bytes
    dpvacm.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 21504 bytes
    dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 35328 bytes
    dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 60928 bytes
    dpserial.dll: 5.00.2134.0001 Swedish Final Retail 9/28/2001 16:00:00 53520 bytes
    dinput.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 162304 bytes
    dinput8.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 184832 bytes
    dimap.dll: 5.01.2600.0000 English Final Retail 9/28/2001 16:00:00 44032 bytes
    diactfrm.dll: 5.01.2600.0000 Swedish Final Retail 9/28/2001 16:00:00 395264 bytes
    joy.cpl: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:54 68608 bytes
    gcdef.dll: 5.01.2600.0000 Swedish Final Retail 9/28/2001 16:00:00 76800 bytes
    pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:46:42 35328 bytes
    dsound.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 367616 bytes
    dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 1294336 bytes
    dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 19456 bytes
    dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 181760 bytes
    dsdmoprp.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 71680 bytes
    dmusic.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 104448 bytes
    dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 28672 bytes
    dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 61440 bytes
    dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 181248 bytes
    dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 35840 bytes
    dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 105984 bytes
    dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 103424 bytes
    dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:34 82432 bytes
    dx7vb.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 619008 bytes
    dx8vb.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 1227264 bytes
    dxdiagn.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:34 2113536 bytes
    mfc40.dll: 4.01.0000.6140 English Final Retail 9/28/2001 16:00:00 924432 bytes
    mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 01:33:44 1028096 bytes
    wsock32.dll: 5.01.2600.2180 Swedish Final Retail 8/4/2004 01:34:06 24576 bytes
    amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:33:30 70656 bytes
    devenum.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:32 59904 bytes
    dxmasf.dll: 6.04.0009.1125 Swedish Final Retail 8/4/2004 01:33:34 498205 bytes
    mciqtz32.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:44 35328 bytes
    mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:34:54 148992 bytes
    msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:33:46 14336 bytes
    encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:33:36 20480 bytes
    qasf.dll: 9.00.0000.3250 Swedish Final Retail 8/4/2004 01:33:54 237568 bytes
    qcap.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 192512 bytes
    qdv.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 279040 bytes
    qdvd.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 385536 bytes
    qedit.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 562688 bytes
    qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 01:31:58 733696 bytes
    quartz.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:54 1289728 bytes
    strmdll.dll: 4.01.0000.3928 Swedish Final Retail 8/4/2004 01:34:00 246302 bytes
    iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 01:34:54 199680 bytes
    ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 01:34:54 848384 bytes
    ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 01:33:42 120320 bytes
    ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 01:33:42 338432 bytes
    ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 01:33:42 755200 bytes
    ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 01:33:42 200192 bytes
    ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 01:33:42 183808 bytes
    ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 01:34:54 154624 bytes
    mswebdvd.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:50 204288 bytes
    ks.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 23:15:22 140928 bytes
    ksproxy.ax: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:54 130048 bytes
    ksuser.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:33:42 4096 bytes
    stream.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 23:08:04 48640 bytes
    mspclock.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 22:58:40 5376 bytes
    mspqm.sys: 5.01.2600.2180 Swedish Final Retail 8/3/2004 22:58:42 4992 bytes
    mskssrv.sys: 5.03.2600.2180 Swedish Final Retail 8/3/2004 22:58:42 7552 bytes
    swenum.sys: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:46:42 4352 bytes
    mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 01:34:54 118272 bytes
    msvidctl.dll: 6.05.2600.2180 Swedish Final Retail 8/4/2004 01:33:48 1431040 bytes
    vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:34:54 30720 bytes
    msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:46:42 17408 bytes
    wstdecod.dll: 5.03.2600.2180 Swedish Final Retail 8/4/2004 01:34:06 51200 bytes
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,,
    WMSpeech Decoder DMO,0x00600800,1,1,,
    Mpeg4s Decoder DMO,0x00800001,1,1,,
    WMV Screen decoder DMO,0x00800001,1,1,,
    WMVideo Decoder DMO,0x00800001,1,1,,
    Mpeg43 Decoder DMO,0x00800001,1,1,,
    Mpeg4 Decoder DMO,0x00800001,1,1,,
    WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
    Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
    DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
    Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
    WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
    AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
    WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
    Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
    Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
    WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
    WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
    Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
    WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
    MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
    ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
    File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
    WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
    Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
    Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
    Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
    WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
    ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
    NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
    Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
    Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
    Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
    Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
    WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
    Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
    DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.07.0000.0001
    WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
    WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
    Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
    DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
    File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
    WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
    DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
    Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
    AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
    .RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
    WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
    Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
    Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
    ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
    DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
    9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
    WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
    Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
    Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
    WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
    Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
    Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
    QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
    Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
    MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
    File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
    XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
    AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
    File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
    File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
    WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
    QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
    Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
    Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
    Datatransformationer för WDM-direktuppspelning:
    Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
    Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
    Video Compressors:
    MSScreen encoder DMO,0x00600800,1,1,,
    WMVideo9 Encoder DMO,0x00600800,1,1,,
    MSScreen 9 encoder DMO,0x00600800,1,1,,
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
    Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
    DivX® 6.7 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
    DivX® 6.7 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,,
    WMAudio Encoder DMO,0x00600800,1,1,,
    IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
    ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
    DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
    Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
    Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
    GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
    Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
    Inspelningsenheter för WDM-direktuppspelning:
    Vinyl AC'97 Audio (WAVE),0x00200000,3,2,,5.03.2600.2180
    Renderingsenheter för WDM-direktuppspelning:
    Mixerenheter för WDM-uppspelning:
    Microsoft Kernel-wave-ljudMixer,0x00000000,0,0,,
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
    Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
    XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
    Audio Renderers:
    Ljuddrivrutin för Microsoft RDP,0x00200000,1,0,quartz.dll,6.05.2600.2180
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
    DirectSound: Ljuddrivrutin för Microsoft RDP (emulerad),0x00200000,1,0,quartz.dll,6.05.2600.218 0
    Systemenheter för WDM-direktuppspelning:
    Vinyl AC'97 Audio (WAVE),0x00200000,15,3,,5.03.2600.2180
