Rally stupid question, hopefully an easy answer...
  • Rally stupid question, hopefully an easy answer...
    I have a 'media player' option in my front-end. It simply uses the AxWindowsMediaPlayer object.
    I have set it up so that I control the video playing with my own controls and the media player is just the playing video. I have made it so when I click the video, it resizes the mediaplayer to fit the screen and if I click it again, it sizes back to its original position, in my form.
    I have everything working exactly as I want apart from one thing....
    If the video is 'double clicked', the mediapayer goes into full screen mode, and I don't want this, can the double click option be disabled. I have looked everywhere for it.
    Also, when in full screen mode, the mouse click pauses the video.
    Help
    PS. The title should say Really, not Rally, perhaps I am as stupid as the question
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    I have had the same problem, with my system. However from reaseaching the solution, I have found that the codec being used to play the video, is what causes the video to do what it does. check if you codec software has some kind of option to turn off the mouse. I am working on a commerical software so I really cant go into detail but. you can (depending on what programming language you are using) Use the windows API calls the capture mouse clicks outside your form and respond to them how you see fit.
    Help
    LilliPut Housing Complete
    MAP POINT WITH EARTH MATE
    TV/FM/XM
    1.7 GHZ 500MB RAM , 60 GB HD
    SLIM LINE DVD DRIVE
    FRONT END: CUSTOM A.N.D.I. - M.P
      I believe there is an option to disable the clicking of the embedded object... This is a property of the axWMP object. You will want to control the sizing of the object in the clicked event of the OLE object.
      Play with it, 'til it's broke.
        Sorted it,
        In the properties, simply set 'Ctlenabled' to Fasle.
        7" Lilliput
        120Gb Sata drive
        1GB RAM
        (Always tweaking!)
