Windows Media Player and MSWebDVD!
  • Windows Media Player and MSWebDVD!
    I have been writing my front-end for a while now and been struggling with the DVD player part. I have posted a few questions on here about DVD playback. I have tried DirectShow (well I looked at it and didn't understand any of it). Then I started to use WMP, but for some reason I can only get audio through media player, no picture. So I turned to MSwebDVD! Seems like it should do the trick, but..... How do you tell MSWebDVD what DVD drive you are using? I have 2 DVD drives and a few DVDs on my hard disk, surly I should be able to access eaither drive or play DVDs of the hard disk...
    I tried.....
    MSWebDVD.dvddirectory="P:\video_ts\"
    and
    MSWebDVD.dvddirectory="M:\video_ts\"
    and
    MSWebDVD.dvddirectory="F:\dvd\video_ts\"
    p: and m: are DVD drives, f: is a hard disk
    ....but all i get is "There is no DVD disc in the drive. Please insert a disc, and then try again."
    Anyway, if I use this...
    MSWebDVD.Play()
    sometimes, it will play a dvd in one of the drives, then without doing anything different, I run the program again and get "No such interface supported", fustration
    So after getting frustrated with MSWebDVD, I had another look at WMP. I downloaded and installed the NVidia DVD codec and at last I can see the video and hear the sound, things were looking good, apart from....
    When using WMP to play a file, mpg, avi etc. you can use the command...
    - mediaPlayer.Ctlcontrols.currentPosition =
    to jump to a specific time, but when playing a dvd this doesn't work, nothing happens.
    also
    returns the position of where you are in seconds when playing a media file, but when playing a DVD it gives you the current time in the chapter.
    Can anyone help with any of the niggles I have, any help would be much appriciated.
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    Update as regards to MSWebDVD
    Right, if I run this code:
    MSWebDVD.play()
    and I have a DVD in P:, physical DVD drive, MSWebDVD will play my DVD from my hard drive f:
    Without a DVD in the drive I always get the error message "There is no DVD disc in the drive. Please insert a disc, and then try again."
    Why does there have to be a disc in the DVD drive to play a VIDEO_TS folder from the hard drive?
    The microsoft website doesn't say anything about this.
    Anyone else had this happen, and is there any sort of work around?
    Thanks again
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
