DS-ATX Control GUI: Ideas, Features & Requests
  • DS-ATX Control GUI: Ideas, Features & Requests
    Hi,
    Thanks to some great work by Alex, there is now a way to control your DSATX in realtime from within RR (or any other skinable FE I'd imagine).
    http://www.mp3car.com/vbulletin/soft...interface.html
    Can we have some suggestions, ideas and requests for features that you would like to see in this new GUI.
    Currently the GUI is a (3 tab) skin within RR.
    It shows:
    Tab 1) The current state of the DS-ATX
    Tab 2) All the variables (wiuth explanations of what they do) - and will allow modification of any variables that are write enabled.
    Tab 3) Settings - Set the port, auto-connect timeout and show/hide debugging output.
    In addition to this, when the DS-ATX goes into shutdown mode (and you are on the DS-ATX skin, a window will popup allowing you to chose between a 10second, 5minute or 30 minute shutdown timer.
    Pretty neat huh?!?!
    If Alex says its ok, then I'd also like to know if any skinners/artists would like to make some skins/graphic enhancements to this skin.
    Ice
    Heres 2 to start off....
    Shutdown Pop Up Window (Idea):
    Having the 'Shutdown Timer Selection' window popup ontop of any other window in RR.
    That way, it doesnt matter where you are (in what screen), if you turn off ACC the window appears (fade-in, popup, dissolve, fold-out, etc) and you can select the option you want and then leave the car. Or press the 'Dismiss' button, if you want to leave it as is.
    Shutdown Timer (idea):Along with the other timer options (perhaps which can be user defined), can we have an option that is 'Shutdown After CD Rip Completes'.
    I have no idea how to check for this, but it would be neat. I often start a RIP and leave the car to go inside.
    Ice
      Cant believe noone is interested?!?!?!
      Amp Turn-on/off (idea):
      Toggle button to turn the Amps on/off (remote amp turn on/off).
      This could also have an Auto-on/off feature, to switch the amps on when windows starts and off again before it shutsdown.
        Give it time
        I ll do my best to imlpement the popup and the rest, I have still have not repaired my carpc and i ll be leaving for a week, but I just wanted to assure you this isn t dead
        Alex
          I'm watching
          Just setting up the dsatx and 'puter in the car right now. Have yet to try the interface also.
          Give it time..........
          Leonardo Da Vinci
            I too am shocked, this would be very handy, but well just have to see were it goes.
            Well done Alex, Jeff and Ice!!
            New Car PC Build list in progress
              I think this is really great stuff & I'm watching both threads... I would love for acentrafuse plugin, but have no clue how to do anything about it
                Centrafuse is a .NET based application. if Centrefuse has any API, I could modify my GUI in. RR might be an issue for me since it is not a .NET application. Though I could provide a COM interface, but I'd have to learn how RR does its screens.
                Software Developed:
                DS-ATX Controller Interface
                Laptop Shutdown Controller
                Considered Projects:
                TPMS Interface
                Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
                  Any News on this?
                  My Project: German/English
                    I have not put any effort into this. There just doesn't seem to be much interest.
                    Software Developed:
                    TPMS Interface
                      Has any further developments been achieved on this? Would love to see some more love for the DSATX in rr
                        For Centrafuse is now a plugin available!
                          I don't use CF, so I hope some skilled programmers can make it more useful in an open FE enviroment like RR.
                          So has any further discussions been done to move this forward into ROADRUNNER
                            Interested!!
                            Where can I get a copy of your plugin? I am really interested in having my DSATX add 30 min to shutdown on days when I need to Upd8.
                            Also I would like to be able to have the plugin trigger the dsatx aux after everything is loaded to turn on my amp.
                            Keep developing bro, we all just didn't realize we needed it or probably just didn't see your post.
                              hi guys,
                              sorry for not making any more progress on this but I have not had my carputer back for more than an year and there aren't any plans of adding one to the new car so far
                              i can post the sources of what i've done it s nothing complicated, if anyone wants to keep at it. It was built in Flex/Flash.
                              thanks again to everyone that helped/posted about this
