Can't change map color in iGuidance 4
  • Can't change map color in iGuidance 4
    Just what the title says. I can change day and night. Night is still white with flourecant writing and I can;t read it. Day looks white, not even yellow like it is supposed to be. If I click to change it to anything, fucia, gray etc...Nothing happens... I didn't touch anything to do with the file system either. Just like that form the install. Everything else works flawlessly...Any ideas? Thanks
    delete theme.ini in the same directory as iGuidance.exe
    AutoPC v1 (Retired) - AutoPC v2 (in progress) - www.shocknet.us
      Ok? Will try it/...
        Well...Wow..? That worked!
          You can also modify theme.ini for different color schemes but deleting it will restore the defaults. Had a similar problem with iGuidance 3.0.
