Fm Radio On Any Front End
  • Fm Radio On Any Front End
    Is there anyone out there using a FM tuner on their FRONTEND.
    if so what one are you using, FE and tuner.
    New at this just asking for a pointed finger in the right direction.
    Anyone want to help me build one too a carpc
    Thank you
    I'm using Centrafuse with the Silabs usb receiver (which btw as it turns out is the same module as the cheaper Brando receiver in a different case.)
    I installed my carpc into my pet Kangaroo, mate.
      Visteon hd radio.
      "Search" will turn turn up lots of stuff.................
      For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
      Leonardo Da Vinci
        RR + Shock Skin
        Visteon HD tuner
        Serial Interface
        AutoPC v1 (Retired) - AutoPC v2 (in progress) -
          RR + MMIv2
          Directed HD Tuner w/ mitchjs serial cable
          Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
            Was thinking about the Visteon HDZ300, but just realized my Motherboard only has one serial port! Maybe theres a USB to serial adapter, or mitch has something like that?
              I'm using the Directed HD with Mitch's cable and a serial to USB adapter
              TruckPC - gutted, being used for test setup
              BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
              BlazerPC - Nexus 7 with Timur's USBROM
                Ok. So I could use the same setup only with the visteon-mitch's serial cable and a basic ser to usb adapter right? Will RR + the DFX skin work out with that setup?
                Found the Visteon pretty cheap this am online!
