Fm Radio On Any Front End
  • Fm Radio On Any Front End
    Is there anyone out there using a FM tuner on their FRONTEND.
    if so what one are you using, FE and tuner.
    New at this just asking for a pointed finger in the right direction.
    Anyone want to help me build one too a carpc
    Thank you
    I'm using Centrafuse with the Silabs usb receiver (which btw as it turns out is the same module as the cheaper Brando receiver in a different case.)
    I installed my carpc into my pet Kangaroo, mate.
      RR
      Visteon hd radio.
      "Search" will turn turn up lots of stuff.................
      Leonardo Da Vinci
        RR + Shock Skin
        Visteon HD tuner
        Serial Interface
          RR + MMIv2
          Directed HD Tuner w/ mitchjs serial cable
          Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
            Was thinking about the Visteon HDZ300, but just realized my Motherboard only has one serial port! Maybe theres a USB to serial adapter, or mitch has something like that?
              I'm using the Directed HD with Mitch's cable and a serial to USB adapter
              TruckPC - gutted, being used for test setup
              BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
              BlazerPC - Nexus 7 with Timur's USBROM
                Ok. So I could use the same setup only with the visteon-mitch's serial cable and a basic ser to usb adapter right? Will RR + the DFX skin work out with that setup?
                Found the Visteon pretty cheap this am online!
