Windows bad shutdown boot menu
  • Windows bad shutdown boot menu
    >>>>>>>>>>>>>>>>>>HELP<<<<<<<<<<<<<<<<<<<<<
    OK now how do i have windows not show the boot menu and boot strait to normal mode instead of safe mode
    I remember seeing a setting for ther delay of that message i could lower it to 2 secs but i cant remember were it is
    Apple Ipod 20gig 4th gen black and white. Saves you lots of time. and a pocketpc with wifi for the ocasional email cheking and mapping at a hotspot.
    Forgot to do a search this is what i found and it will work oops
    From another post
    __________________________________________________ _
    Sorry for not answering earlier but I have been on vacation ...
    Here is what to do:
    Edit the c:\msdos.sys and make sure you have the folowing settings:
    BootMenu=0
    BootWarn=0
    AutoScan=0
    It should do the trick.
    // Markus
    More information aboute the msdos.sys options....
    The [Options] section can contain the following settings and must be
    manually inserted:
    AutoScan=
    Default: 1
    Purpose: Defines whether or not ScanDisk is run after a bad shutdown.
    A setting of 0 does not run ScanDisk; 1 prompts before
    running ScanDisk; 2 does not prompt before running
    ScanDisk but prompts you before fixing errors if any
    errors are found.
    This setting is used only by OEM Service Release 2 and
    Windows 98.
    BootMenu=
    Default: 0
    Purpose: A setting of 1 enables the Startup menu. If this setting is 0,
    then you must press the F8 key when "Starting Windows 95"
    appears, (or press and hold the CTRL key when your Windows
    98-based computer restarts) to invoke the Startup menu.
    BootMenuDefault=
    Default: 1 if the system is running correctly
    3 if the system hung in the previous instance
    Purpose: Use this setting to set the default menu item for startup.
    BootMenuDelay=
    Default: 30
    Purpose: This setting is used to set the number of seconds your system
    will pause on the Startup menu. If the number of seconds counts
    down to 0 without intervention, the BootMenuDefault is activated.
    NOTE: This option is not functional unless BootMenu=1 has been added to
    the [Options] section of the Msdos.sys file.
    BootWarn=
    Default: 1
    Purpose: A setting of 0 disables the safe mode boot warning message and
    the Startup menu.
