mp3 updating?
  • mp3 updating?
    When copying new mp3's to your mp3 directory on your car, how do you update winamp or whatever with the new songs you just added? Do you update it by hand or have a script for it to re-read the directory, or what?
    24 y/o w/ Silver/Red
    2000 Honda S2000
    I don't use Winamp, but all I do is pop open the database in Access and add the new files.
    My untimate solution will be to use wireless syncronization, which will automatically copy the files and database everytime I pull into the driveway.
      i use the albumlist plug-in for winamp and it is configured to scan directories i tell it to for new files every time winamp starts up
      99.9% complete.
        You get this working, And I promise I wil buy this from you.
          It's not like this is a terribly difficult task. If you already have wireless set up, all you need to do is write a simple small program that when it detects the connection to your home computer, connect to the directory where your music is stored, copy any new files and append them onto a database.
          You could probably even do that in a batch file
          IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
            Squeezer- I use a removable drive for all my stored music with a macro to play a command line.
            example: "C:\Program Files\Winamp\winamp.exe" "D:\Music"
            This way a dir is loaded and not a playlist.m3u file so all new music is loaded. You can also add more keystrokes to your Macro's to "sort by path and filename" once the dir is loaded so everything is in alphabetical order. It can all be done with a single button press. If you don't have a removable drive how are you currently updating your MP3 files? do you network with a home computer? wireless syncronization? tell us how your current setup is .
            GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
            VW Bus - 10.4" vga lcd. Loaded with same software as above.
              Media Engine has the capability to read new songs on the fly. All you have to do is dump the new songs into a directory, and then media engine will find them
              Get MediaEngine !!!
              Media Engine Download
                dir/b/s > playlist.m3u
                Status: I still need to get some money to buy the inverter.
                  my application (which im gonna release this week) uses a small utilty that re-scans your mp3 folder and re-creates winamp playlists to create a 'semi-database'....
                  Project - GAME OVER :(
                    I have already made the wireless sync program that works beutifully, it syncs up to 4 directories each time your wireless network comes in range (ie this could be your mp3 directory, playlist directory etc). I have the beta version on my site at the moment, but the final is coming out on monday. So if you can wait till then, you'll be pleasantly supprised with what it can do.
                    There is another bloke doing a similar thing, so it won't be long until everyone is making these syncers, but it so makes your life easier!
                    BjBlaster! Car MP3 & Carputer!
                    "The solution to one problem is only the beginning of another"
                      that sounds cool..... something else to add to my app
                      just gotta get some wireless networking jazz...... got my new SB Audigy on the weekend, so after that is runnin wireless networking toys might be next
                        Like Loftus, I use a directory/sub-directory setup and a removable hard drive. I just copy the new song the the appropriate directory or sub-directory and it sorts it automatically.
                        I run everything from batch files for minimum keystrokes.
                          Wireless Sync
                          Here you go:
                          Silver 1999 Nissan Pathfinder!
                          Completion: [*********-] 90%
                          Everything working! Mobile MP3s ROCK!
                          LEFT TO DO: Improve power on circuit, fix slow boot time
                          - 550mhz PIII on Abit BH6
                          - 128MB RAM
                          - 40x4 Backlit Character LCD
                          - 17 key numeric keypad - Repainted buttons
                          - 2.1GB laptop drive for OS
                          - 4.3GB drive for MP3s
                 Redesigned, new pics!
