Full XP on USB,someone tryed this?
  • Full XP on USB,someone tryed this?
    This isn't my work ,it's result of search for fast OS witch can be loaded from something else then CF card or HD
    to avoid danger of engine cranks and road bumps and to be cheap solution for anyone with carputer.
    Here is Full "How to"
    My expirience isn't good enough to try ,may be some of you guys could try ,I think it's briliant if is possible.
    orig. link :
    Installing and booting Windows XP from USB drive -- Guide
    (last updated: 11.06.2006 12:23:26 ) created by emanuel
    ( on 03.03.2006 14:08:51 )
    What is this about?
    ...must go to the people that made this guide possible in the first place. In recent months, a few blokes going
    by the handles of mkiaer, Dietmar and sisal and a few others from the forums came up with many good pieces
    of research on how to enable any NT-based Windows to boot from a USB-drive. Little of this guide would exist without
    them - in fact the only reason why i write this up is that my particular solution seems to be lower effort than any
    of the steps i saw before. Many of the steps here are the result of their research.
    Version History:
    v1.0 - 3rd Mar 2006
    rewritten, tested and working against two different drives with my laptop.
    v0.9 - 29th Feb 2006
    initial version, untested
    What works?
    Basically, everything as far as i can see. After completing this tutorial, your Windows XP install should directly
    boot off your USB-drive, and be fully upgradable, DirectX games will run, all apps i tested work like normal, speed
    is the same as with a real HDD (you need USB2 though) - so it is in fact a fine solution as far as i can see.
    This is a hobby project of mine. I will not assume ANY responsibility for the correctness of this guide, nor can I be
    made liable for any errors, hardware or software problems / loss that are caused by following this guide. Basically, if things screw up, its your own fault. Do not follow the guide if you fear data loss.
    An existing Windows install for carrying out the steps in this tutorial
    A USB2-compliant Hard disk drive (or a big USB2 stick, see remarks below)
    An original Windows XP CD (tested only against SP1 so far, but reported to work on other versions)
    A registered version of WinISO (or any other software that allows direct editing of ISO files)
    The Microsoft CAB SDK
    A CD-burning software that can handle ISO files. I like the free burnatonce
    How To:
    We will dump the contents of your original Windows XP CD , extract a few files from the Image using ISO modification software, edit the files, and put the modified versions back on the ISO. The resulting ISO image is burnt back onto a CD media, and can then directly be used to install Windows on your USB drive.
    I am also covering a few pitfalls that happened to me, in hope they will save you a bit of time.
    1) Does your computer support booting from USB?
    Usually, if its an option in your BIOS boot sequence menu, the answer to this is yes. If its not there, look for BIOS updates. If you are not sure, proceed and see what happens ;-)
    2) Sorting out the "Bootability" of your USB-Drive
    Connect your USB drive to your computer, directly, without a Hub. Then, shut down your computer, disconnect any other hard disk drives from it, and insert your original Windows XP CD into the drive. Start the installation, and proceed to the section where you are allowed to pick a hard drive. If it goes beyond the partition selection, your drive is already fine for booting Windows XP. If not (seems to be the cases with many of the Freecom USB HDDs for example), you will get an error like "Windows is unable to find your drive, partition, data etc bla". This is usually not a big problem. All you need to do is "properly" format the drive. Reboot into your normal Windows, and get this HP tool , and use it to format your HDD completely. I chose NTFS format, worked fine everytime i tried. After this, my drives are recognized as valid installation devices by the Windows XP installer.
    (In fact, i did not manage to create a USB primary partition with FAT32 that was recognized as being installable)
    3) Dumping the original Windows CD into an ISO File
    Pretty easy one. Simply open WinISO, and select Actions -> Make ISO from CDROM, and save your CD image.
    4) Extracting the files we need to work on
    After the CD dump is done, close and reopen WinISO. Then, open the ISO file you just created using File -> Open.
    Now, click the I386 folder, and select the following files (Ctrl key to multi-select)
    Select Actions -> Extract and put the resulting files into some folder to work on them.
    5) Unpacking IN_ files
    Use the Cab SDK (from the command line) for extracting the contents of the .IN_ files. Each of them contains exactly one .inf file. If you are unsure how to use the Cab SDK, here is an example command line: "cabarc x USBSTOR.IN_" . You should end up with three new files in the folder, called:
    You can now delete the .IN_ files.
    6) Editing the files
    This is the main job. i ll also try to explain a bit whats happening. Use a simple Texteditor like Notepad.
    This file is loaded on the initial install step by the Windows XP CD installer. In this file, we will change the way Windows treats USB devices during system setup -- the default is to only treat them as input devices during installation -- we will change this to include mass storage driver support (which needs to be loaded into the installer much earlier in order to work).
    First, move the following entries from [InputDevicesSupport.Load] to the [BootBusExtenders.Load] section , as shown here
    pci = pci.sys
    acpi = acpi.sys
    isapnp = isapnp.sys
    acpiec = acpiec.sys
    ohci1394 = ohci1394.sys
    usbehci = usbehci.sys
    usbohci = usbohci.sys
    usbuhci = usbuhci.sys
    usbhub = usbhub.sys
    usbstor = usbstor.sys
    usbhub = usbhub.sys
    usbccgp = usbccgp.sys
    hidusb = hidusb.sys
    serial = serial.sys
    serenum = serenum.sys
    ... now the same for [BootBusExtenders] and [InputDevicesSupport]
    pci = "PCI-Bustreiber",files.pci,pci
    acpi = "ACPI Plug & Play-Bustreiber",files.acpi,acpi
    isapnp = "ISA Plug & Play-Bustreiber",files.isapnp,isapnp
    acpiec = "Integrierter ACPI-Controllertreiber",files.none,acpiec
    ohci1394 = "IEEE-1394-Bus-OHCI-konformer Anschlusstreiber",files.ohci1394,ohci1394
    usbehci = "Erweiterter Hostcontroller",files.usbehci,usbehci
    usbohci = "Open Hostcontroller",files.usbohci,usbohci
    usbuhci = "Universeller Hostcontroller",files.usbuhci,usbuhci
    usbhub = "Standard-USB-Hubtreiber",files.usbhub,usbhub
    usbstor = "USB-Speicherklassentreiber",files.usbstor,usbstor
    hidusb = "HID-Parser",files.hidusb,hidusb
    serial = "Treiber fr seriellen Anschluss",files.none,serial
    serenum = "Enumerator fr seriellen Anschluss",files.none,serenum
    usbccgp = "USB Generic Parent Driver",files.usbccgp,usbccgp
    Next, we also have to write several keys into the registry. Convieniently, the txtsetup.sif allows you to specify files that are parsed and instered into the registry at install time. Insert the following in the [HiveInfs.Fresh] section:
    AddReg = hivedef.inf,AddReg
    AddReg = hivesys.inf,AddReg
    AddReg = hivesft.inf,AddReg
    AddReg = hivecls.inf,AddReg
    AddReg = hiveusd.inf,AddReg
    AddReg = dmreg.inf,DM.AddReg
    AddReg = usbboot.inf,usbservices
    and also in [SourceDisksFiles]
    usbboot.inf = 1,,,,,,_x,3,,3
    bootvid.dll = 1,,,,,,3_,2,0,0,,1,2
    kdcom.dll = 1,,,,,,3_,2,0,0,,1,2
    Finally, save and close TXTSETUP.SIF. We are done with it.
    Now, open DOSNET.INF , and change the second [Files] section to look like this:
    6-C) usb.inf
    Change the bolded lines in the [StandardHub.AddService] and [CommonClassParent.AddService] sections:
    DisplayName = %StandardHub.SvcDesc%
    ServiceType = 1 ; SERVICE_KERNEL_DRIVER
    StartType = 0 ; SERVICE_DEMAND_START
    ErrorControl = 1 ; SERVICE_ERROR_NORMAL
    ServiceBinary = %12%\usbhub.sys
    LoadOrderGroup = Boot Bus Extender
    DisplayName = %GenericParent.SvcDesc%
    ServiceBinary = %12%\usbccgp.sys
    6-D) usbport.inf
    Change the bolded lines in the [EHCI.AddService], [OHCI.AddService] , [UHCI.AddService] and [ROOTHUB.AddService] sections:
    DisplayName = %EHCIMP.SvcDesc%
    ServiceBinary = %12%\usbehci.sys
    DisplayName = %OHCIMP.SvcDesc%
    ServiceBinary = %12%\usbohci.sys
    DisplayName = %UHCIMP.SvcDesc%
    ServiceBinary = %12%\usbuhci.sys
    DisplayName = %ROOTHUB.SvcDesc%
    6-E) usbstor.inf
    Change / Add the bolded lines in the [USBSTOR.AddService] section
    DisplayName = %USBSTOR.SvcDesc%
    ServiceType = 1
    StartType = 0
    Tag = 3
    ErrorControl = 1
    ServiceBinary = %12%\USBSTOR.SYS
    6-F) new file: USBBOOT.INF
    Create a new file called USBBOOT.INF in the same directory as your other changed files, and put the following content into it:
    HKLM,"SYSTEM\CurrentControlSet\Services\USBSTOR"," DisplayName",0x00000000,"USB Mass Storage Driver"
    HKLM,"SYSTEM\CurrentControlSet\Services\USBSTOR"," ErrorControl",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\USBSTOR"," Group",0x00000000,"System Reserved"
    HKLM,"SYSTEM\CurrentControlSet\Services\USBSTOR"," ImagePath",0x00020000,"system32\DRIVERS\USBSTOR.SY S"
    HKLM,"SYSTEM\CurrentControlSet\Services\USBSTOR"," Start",0x00010001,0
    HKLM,"SYSTEM\CurrentControlSet\Services\USBSTOR"," Type",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbehci"," DisplayName",0x00000000,"USB 2.0 Enhanced Host Controller Miniport Driver"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbehci"," ErrorControl",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbehci"," Group",0x00000000,"System Reserved"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbehci"," ImagePath",0x00020000,"system32\DRIVERS\ s"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbehci"," Start",0x00010001,0
    HKLM,"SYSTEM\CurrentControlSet\Services\usbehci"," Type",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbhub","D isplayName",0x00000000,"USB2 Enabled Hub"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbhub","E rrorControl",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbhub","G roup",0x00000000,"System Reserved"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbhub","I magePath",0x00020000,"system32\DRIVERS\usbhub.sys"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbhub","S tart",0x00010001,0
    HKLM,"SYSTEM\CurrentControlSet\Services\usbhub","T ype",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbuhci"," DisplayName",0x00000000,"Microsoft USB Universal Host Controller Miniport Driver"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbuhci"," ErrorControl",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbuhci"," Group",0x00000000,"System Reserved"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbuhci"," ImagePath",0x00020000,"system32\DRIVERS\ s"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbuhci"," Start",0x00010001,0
    HKLM,"SYSTEM\CurrentControlSet\Services\usbuhci"," Type",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbohci"," DisplayName",0x00000000,"Microsoft USB Open Host Controller Miniport Driver"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbohci"," ErrorControl",0x00010001,1
    HKLM,"SYSTEM\CurrentControlSet\Services\usbohci"," Group",0x00000000,"System Reserved"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbohci"," ImagePath",0x00020000,"system32\DRIVERS\ s"
    HKLM,"SYSTEM\CurrentControlSet\Services\usbohci"," Start",0x00010001,0
    HKLM,"SYSTEM\CurrentControlSet\Services\usbohci"," Type",0x00010001,1
    7) Repack the inf files into their original IN_ format
    If you have not already deleted your extracted .IN_ files, do so now. They need to be replaced. Open a DOS shell again, and navigate to the folder with your changed files. Then exceute the following commands:
    cabarc n USB.IN_ usb.inf
    cabarc n USBPORT.IN_ usbport.inf
    cabarc n USBSTOR.IN_ usbstor.inf
    The three IN_ files should now exist again.
    Congratulations. All out modifications are done.
    8) Inject the changed files into the ISO
    Open your Windows CD image again with WinISO. Navigate to the I386 folder, and delete the following files from the ISO, saving the changes to the ISO afterwards:
    Just to be sure all is updated in the ISO, cloase and repoen the ISO in WinISO. Now, again go to the I386 folder and select "Add Files". Now add your changed files, in detail:
    Save the ISO. You are done.
    9) Burn the ISO back to CD
    Feel free to use any burning package you want. I used the free and simple Burnatonce
    10) Install Windows XP from the CD
    Shut down your computer. Disconnect ANY internal and external hard drives (so Windows cannot find them during installation and mess up their Master Boot Records hehe). Some computers will have trouble to boot without an internal HDD attached, check in your BIOS and, if possible, remove the HDD from the boot sequence and set the USB Harddisk as the first boot device, and the CDROM as second.
    Also, now connect your USB Harddrive directly to the computer, without any Hubs in between.
    Windows should install just fine, with the exceptions noted below.
    Issues you will encounter during installation:
    During driver installation, the USB drivers will prompt you, as they are "not certified" - This is normal. Our changes invalidated the checksum, and therefore the driver is no longer signed. Just press "yes" a couple of times.
    Upon completion of the install, the system will complain once on the first bootup that the pagefile does not exist. You can ignore this for now, as Windows will work fine without it. People are looking at fixing this issue, but its not critical for now.
    Once everything is up and running , shut down and reconnect all your drives.
    This version of the guide has been tested successfully on the follwoing hardware configurations - please email me your infos if you have successfully completed the guide, so I can add your configuration as well:
    Dell Latitude D810, Freecom FHD-3 80GB USB2 HDD, NTFS formatted using HP tool
    Dell Latitude D810, Western Digital 2206A 80GB USB2 HDD, NTFS formatted using HP tool
    If you have troubles, please visit the forum dedicated to this tutorial.
    have a lot of fun!
    Emanuel Schleussinger
    Mar 2006
    Success Reports
    (last updated: 25.05.2006 23:11:40 ) created by emanuel
    ( on 06.03.2006 14:33:40 )
    Submitter Computer / MotherBoard
    USB Device Tutorial
    JP Morgan
    Dell Latitude D800
    BusLink Usb 2.0 - Pro 2 version -4 gig Flash v1.0 YES
    JP Morgan
    Dell Latitude D800 SimpleTech 4GB USB HDD v1.0 YES
    Emanuel Dell Latitude D810
    Western Digital 2206A HDD
    Emanuel Dell Latitude D810 Freecom FHD-3 80GB v1.0
    Jesper Asus K8N
    Freecom 160GB (unknown)
    v1.0 YES
    tudoggs ZPC64 - Sempron 3100
    Belkin USB2 caddy + Maxtor HDD
    vajkrs GA-8IG1000MK StoreJet TS20GSJ18 USB Device 18GB v1.0 YES
    n/a Dell 630M Lacie usb 2.5 80 GO v1.0 YES
    rgr Toshiba Satellite M40 Fujitsu 20G in Datalink GL811E USB2 caddy
    v1.0 YES
    rgr IBM Thinkpad T41 Fujitsu 20G in Datalink GL811E USB2 caddy v1.0
    xlr8mac Macbook Pro (Intel Duo)
    JessieBlue Gericom 1st Supersonic No name USB2 cage + Quantum HDD
    n/a Shuttle Mini m/b Via Chipset lacie 250gb
