Enhancements to Winamp LCD Plugin
  • Enhancements to Winamp LCD Plugin
    Hi all
    For those interested, i recently developed some enhancements on the great Markus Zehnder's Winamp LCD Plugin. Here is the liste of things added :
    - Added a 10 Band customizable equalizer to the menu.
    - New Output variable : Volume bar.
    - New Output variable : realtime CPU Use.
    - New Output variable : realtime Memory Use.
    - New Output variable : a little spinning top to display playing status.
    - Temporary displays volume bar when volume changes.
    - Added 'Play All' in player settings menu, to enqueue all playlists.
    - Added 'Browse' in player settings menu, to browse all dirves for a particular song or playlist.
    - BugFix : Key handling (block key if bound in plugin)
    - BugFix : Corrected a little spectrum analyser bug
    - Now retrieves playlists only 1 time at initialisation rather than each time when selecting 'Playlists menu'.
    - (T2) Pause and Stop Sets do not periodically rotate as other sets
    - (T2) Browser is now controlled by Up/Down/Left/Righ key assignements which allows going back in directory tree
    - (T2) BugFix : T1 was not working on Win9x because of the PDH API. Now there is a W9x version, which doesn't have the CPU and Memory Use output variables.
    - (T3) Equalizer now has a much better vertical layout
    - (T3) Equalizer can be enabled/disabled from menu
    - (T3) Now the state displays in realtime in menu when enabling/disabling equalizer, shuffle or random
    - (T3) New key binding : Go to next/previous letter in menu
    - (T3) New key binding : When pressing Next/Previous keys while in menu, you advance/go back 10 items in menu
    - (T4) Equalizer displays on the whole screen (more than 2 lines)
    - (T4) Equalizer bands can be adjusted by 1Db steps
    - (T4) Ability to select multiple files to play in the browser
    - (T4) Files are alphabetically sorted in browser
    - (T4) New key binding : Select/unselect ALL file from a directory
    - (T4) BugFix : Corrected spec analyzer and volume bars for LCDs that dont have block character on 0xFF code
    - (T4) BugFix : Corrected bugs between spec analyzer and equalizer
    I recently got contact with markus and we will soon join our efforts on this plugin.
    My homepage for this plugin is http://www.poulpy.com/lcdplugin (Page is partially in French but you can download the english version of the plugin).
    Let me know what you think of it
    TiTi
    Spectrum
    How do I get this Spectrum to Work?
      Sounds cool, too bad I can't read French
      Silver 1999 Nissan Pathfinder!
      Completion: [*********-] 90%
      Everything working! Mobile MP3s ROCK!
      LEFT TO DO: Improve power on circuit, fix slow boot time
      - 550mhz PIII on Abit BH6
      - 128MB RAM
      - 40x4 Backlit Character LCD
      - 17 key numeric keypad - Repainted buttons
      - 2.1GB laptop drive for OS
      - 4.3GB drive for MP3s
      http://www.mp3car.com/usersites/bombboyer/ Redesigned, new pics!
        Markus will soon be integrating my code.
        btw my site is partially in french but the plugin is in full english
