Help with Remote Control Configuration
  • Help with Remote Control Configuration
    Hello all,
    I am hoping the brains on this board can help me with this.
    I am using IRMan to control Winamp in a WinXP environment. Right now, I am using the Winamp plugin that came with the IRMan software to run Winamp. It is working fine for choosing songs, pause, etc.
    However, I would like to be able to use my remote control to also load Winamp. Any ideas about the best way to do that would be greatly appreciated.
    Also, a general question for those who are using Winamp: Are the Winamp plugin that comes with the IRMan installation disk and the Gen_IR Winamp plugin on the Evation website the same thing? If not, which is preferable?
    Thanks in advance.
    Kevin
    take a look at this site. this program works with the Irman and let you do much more then just controle winamp.
    www.girder.nl
    PETER - THE NETHERLANDS - DEVENTER
    sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
      PC remote
      I like PC remote better than guilder its much easier to use. If you need a crack for it let me know.
        Thanks for the replies, guys.
        Jay, what is PC Remote? Does it work with IRMan? Do I need a special remote?
          Yeah it works with IRman thats what im using. what it does is let you asign a key to a button on the remote, I use it with Markus`s LCD plug in with the keyboard commands. Ite easy to set up. and nice.
            Thanks, Jay. Where do I find the program? Can one use it to load as well as control Winamp?
              Yep, I have PC remote launch on startup up as well as winamp with Markus`s LCD software for winamp. and Im very happy with this setup.works nice.
                I actually don't want to have Winamp load at startup. I want to be able to launch Winamp with the remote. Will this program allow me to do that?
                Also, do you know where I can find the program?
                Thanks.
                Kevin
