Function Generator [Work In Progress]
  • Function Generator [Work In Progress]
    So, here is the GIU for it so far.
    It will show the Frequency via numbers in the top box, and I hope to be able to pull off a very basic graphic of an oscilloscope in the bottom.
    I just wanted a cool way to play test tones, and have seen people use actual function generators to do so.
    I figured..hey..why not make a software version?
    Now I have to figure out how to get Visual basic to output a test tone.
    The quick and dirty way would be to simply have a sound file for each freq, but I am hoping to be able to produce the sound on the fly.
    You'll need some outside help to get VB to output a tone. As far as I know, it can't do it on it's own.
    Christmas Car Project 2008
    ArrowDash Skin Worklog
      It can do it by itself.
      It can either load the file up and play it, or it can calculate the sound and write it to file at run time.
      The latter requires knowledge of how a .wav file is composed on a byte level. So for now I will be using the first method. Version 2.0 will use the latter method once I have time to work it out.
        VB can most certainly play tones. Here is some code to generate a small wav file. Just use the Windows Media Player 6.4 control. That should be good enough. Just put the small wav file in a loop.
        Code:
        'Write sound data to wave files
        'By Axel Brink
        '21-May-2002
        'Write comments to [email protected]
        'You can use this file freely, at your own risk
        'Credits would be appreciated, but are not necessary
        'Please do not redistribute this source code without my name
        'Wavefile format information used from http://ccrma-www.stanford.edu/CCRMA/Courses/422:1998/projects/WaveFormat/
        'Some comments from this address are copied here (marked ##)
        'Example use:
        'Private Sub cmdHighQuality_Click()
        '  Const Hertz As Single = 2 * 3.14159265 / 44100 'use sin(sam*hertz) to get a tone of 1 hertz
        '  Dim DataBytes(0 To 1, 0 To 44099) As Long
        '  Dim sam As Long
        '  Dim chan As Integer
        '  MousePointer = vbHourglass
        '  For sam = 0 To 44099
        '    For chan = 0 To 1
        '      DataBytes(0, sam) = 4000 * Sin(500 * sam * Hertz)
        '      DataBytes(1, sam) = 4000 * Sin(300 * sam * Hertz)
        '    Next chan
        '  Next sam
        '  WriteWave txtOutputPath.Text, CreateWaveArray(DataBytes, 44100, 16)
        '  MousePointer = vbDefault
        'End Sub
        'Private Sub cmdLowQuality_Click()
        '  Const Hertz As Single = 2 * 3.14159265 / 22050 'use sin(sam*hertz) to get a tone of 1 hertz
        '  Dim DataBytes(0 To 0, 0 To 22049) As Long
        '  Dim sam As Long
        '  For sam = 0 To 22049
        '    DataBytes(0, sam) = 127 + 40 * Sin(800 * sam * Hertz) + 40 * Sin(300 * sam * Hertz)
        '  Next sam
        '  WriteWave txtOutputPath.Text, CreateWaveArray(DataBytes, 22050, 8)
        'End Sub
        Option Explicit
        Public Const WAVE_MIN = -32768 'Extreme sample values for 16-bit samples
        Public Const WAVE_MAX = 32767
        Public Function CreateWaveArray(WaveData() As Long, SampleRate As Long, BitsPerSample As Long) As Byte()
        'Reads sample data and returns an array with bytes which can be
        'written to a .wav file
        'Uses PCM (i.e. no compression)
        'WaveData:  * Contents:  Sample values of type Long
        '           * Structure: An array(channel, samplenumber)
        '           * Channels:  The number of elements in the first dimension
        '                        determines the number of channels
        '           * Samples:   The number of elements in the second dimension
        '                        determines the number of samples
        '                        8-bit samples must be between 0 and 255
        '                        16-bit samples must be between -32768 and 32767
        '           Note that indexing is supposed to start at 0.
        'SampleRate:             Number of samples per second. Typically 44100.
        'BitsPerSample:          Number of bits per sample. 8 or 16.
          Const Byte1Mask As Long = 255      'Long integers are stored little endian.
          Const Byte2Mask As Long = 65280    'These bit masks select bytes from a number to store.
          Const Byte3Mask As Long = 16711680
          Const Byte2Divisor As Long = 256
          Const Byte3Divisor As Long = 65536
          Const Byte4Divisor As Long = 16777216
          Dim NumSamples As Long
          Dim NumChannels As Long
          Dim FileSize As Long
          Dim ByteRate As Long
          Dim BlockAlign As Long '## "The number of bytes for one sample including all channels.
                                 '    I wonder what happens when this number isn't an integer?"
          Dim OutputFile() As Byte
          Dim ChunkSize As Long  '## "36 + SubChunk2Size, or more precisely:
        '                               4 + (8 + SubChunk1Size) + (8 + SubChunk2Size)
        '                               This is the size of the rest of the chunk
        '                               following this number.  This is the size of the
        '                               entire file in bytes minus 8 bytes for the
        '                               two fields not included in this count:
        '                               ChunkID and ChunkSize."
          Dim Subchunk2Size As Long '## "== NumSamples * NumChannels * BitsPerSample/8
        '                               This is the number of bytes in the data.
        '                               You can also think of this as the size
        '                               of the read of the subchunk following this
        '                               number."
          Dim SampleNr As Long
          Dim ChannelNr As Long
          If BitsPerSample <> 8 And BitsPerSample <> 16 Then Stop
          NumChannels = UBound(WaveData, 1) + 1
          NumSamples = UBound(WaveData, 2) + 1
          ByteRate = SampleRate * NumChannels * BitsPerSample / 8
          BlockAlign = NumChannels * BitsPerSample / 8
          FileSize = 44 + NumSamples * BlockAlign
          ChunkSize = FileSize - 8
          Subchunk2Size = NumSamples * NumChannels * BitsPerSample / 8
          ReDim OutputFile(0 To FileSize - 1) As Byte
          '** ChunkID **
          OutputFile(0) = Asc("R")
          OutputFile(1) = Asc("I")
          OutputFile(2) = Asc("F")
          OutputFile(3) = Asc("F")
          '** ChunkSize **
          OutputFile(4) = ChunkSize And Byte1Mask 'Little endian
          OutputFile(5) = (ChunkSize And Byte2Mask) \ Byte2Divisor
          OutputFile(6) = (ChunkSize And Byte3Mask) \ Byte3Divisor
          OutputFile(7) = ChunkSize \ Byte4Divisor
          '** Format **
          OutputFile(8) = Asc("W")
          OutputFile(9) = Asc("A")
          OutputFile(10) = Asc("V")
          OutputFile(11) = Asc("E")
          '** Subchunk1ID **
          OutputFile(12) = Asc("f")
          OutputFile(13) = Asc("m")
          OutputFile(14) = Asc("t")
          OutputFile(15) = Asc(" ")
          '** Subchunk1Size ** (16 for PCM)
          OutputFile(16) = 16 And Byte1Mask
          OutputFile(17) = (16 And Byte2Mask) \ Byte2Divisor
          OutputFile(18) = (16 And Byte3Mask) \ Byte3Divisor
          OutputFile(19) = 16 \ Byte4Divisor
          '** AudioFormat ** (1 for PCM)
          OutputFile(20) = 1 And Byte1Mask
          OutputFile(21) = (1 And Byte2Mask) \ Byte2Divisor
          '** NumChannels **
          OutputFile(22) = NumChannels And Byte1Mask
          OutputFile(23) = (NumChannels And Byte2Mask) \ Byte2Divisor
          '** SampleRate **
          OutputFile(24) = SampleRate And Byte1Mask
          OutputFile(25) = (SampleRate And Byte2Mask) \ Byte2Divisor
          OutputFile(26) = (SampleRate And Byte3Mask) \ Byte3Divisor
          OutputFile(27) = SampleRate \ Byte4Divisor
          '** ByteRate **
          OutputFile(28) = ByteRate And Byte1Mask
          OutputFile(29) = (ByteRate And Byte2Mask) \ Byte2Divisor
          OutputFile(30) = (ByteRate And Byte3Mask) \ Byte3Divisor
          OutputFile(31) = ByteRate \ Byte4Divisor
          '** BlockAlign **
          OutputFile(32) = BlockAlign And Byte1Mask
          OutputFile(33) = (BlockAlign And Byte2Mask) \ Byte2Divisor
          '** BitsPerSample **
          OutputFile(34) = BitsPerSample And Byte1Mask
          OutputFile(35) = (BitsPerSample And Byte2Mask) \ Byte2Divisor
          '** Subchunk2ID **
          OutputFile(36) = Asc("d")
          OutputFile(37) = Asc("a")
          OutputFile(38) = Asc("t")
          OutputFile(39) = Asc("a")
          '** Subchunk2Size **
          OutputFile(40) = Subchunk2Size And Byte1Mask
          OutputFile(41) = (Subchunk2Size And Byte2Mask) \ Byte2Divisor
          OutputFile(42) = (Subchunk2Size And Byte3Mask) \ Byte3Divisor
          OutputFile(43) = Subchunk2Size \ Byte4Divisor
          If BitsPerSample = 8 Then 'Samples are unsigned bytes; from 0 to 255
            For SampleNr = 0 To NumSamples - 1
              For ChannelNr = 0 To NumChannels - 1
                OutputFile(44 + BlockAlign * SampleNr + ChannelNr) = WaveData(ChannelNr, SampleNr) And Byte1Mask
              Next ChannelNr
            Next SampleNr
          ElseIf BitsPerSample = 16 Then 'Samples are 2's complement signed bytes; from -32768 to 32767
                OutputFile(44 + BlockAlign * SampleNr + ChannelNr * BitsPerSample \ 8) = WaveData(ChannelNr, SampleNr) And Byte1Mask
                OutputFile(45 + BlockAlign * SampleNr + ChannelNr * BitsPerSample \ 8) = (WaveData(ChannelNr, SampleNr) And Byte2Mask) \ Byte2Divisor
              Next ChannelNr
            Next SampleNr
          End If
          CreateWaveArray = OutputFile
          Exit Function
        End Function
        Public Sub WriteWave(Path As String, WaveArray() As Byte)
          Dim ErrorNumber As Long
          On Error GoTo WriteWaveError
          Open Path For Input As #1
          Close #1
          If ErrorNumber = 0 Then 'File exists
            Kill Path             'Delete
          End If
          Open Path For Binary As #1
          Put #1, , WaveArray
          Close #1
        WriteWaveError:
          ErrorNumber = Err.Number
          Resume Next
        End Sub
        Get MediaEngine !!!
        Media Engine Download
          Well I currently have it working. When using the method above it seems to take several seconds to generate the tone on the fly.
          It is faster, and less prone to error (tapping the buttons fast), when I load up a .wav file.
          I have from 5Hz to 20000Hz sounds, and have made it easy to navigate through them.
          I also got the application loading up in RoadRunner. It works quite nicely.
          Now all I have to do is to polish up some of the GUI, add in the waveform images, and add in some Freq Sweeps to round it out.
          I had thought there would be more interest in this..but then I don't imagine a lot of people here go to SPL competitions.
          I'm sure to win 1rst place for style anyways lol
