My Custom Car PC Front-End
  • My Custom Car PC Front-End
    Hi All,
    My first post on here i thought i'd brag a little about my setup:
    I've written my own frontend for my CarPC as i wasn't happy with the current system i had. The details are on my blog here:
    http://www.lewty.org.uk/blog/?p=105
    There's a screenshot here:
    http://www.lewty.org.uk/images/CarPCInterface.jpg
    But it's not much to look at as all of the output is via a 2x20 Character LCD.
    I've added some photos here:
    http://www.flickr.com/photos/davelew...7612239409392/
    It's not much use to anyone other than me but i wanted to show it off
    Dave Lewthwaite
    www.lewty.org.uk
    dave@lewty.org.uk
    Just thought i'd drag this up for a little update,
    I was forced into writing my own startup/shutdown control software as ShutControl started refusing to run which is annoying. At least this way my app doesn't use any of the .NET stuff so i know it'll run with only a couple of DLLs on Win 2k-7 without issues.
    I've also done the discovery work for the Car2PC adaptor as the winamp plugin now refuses to talk to the headunit, i've got the protocol spec dechiphered (not as obvious as it should be) and sent some test commands and got some test data back from the headunit.
    I'm now going to set about writing the interface. After that i plan to structure the program properly into discrete classes for different pieces of work, then i can consider releasing it as a DLL, or code.
    Dave Lewthwaite
    www.lewty.org.uk
    dave@lewty.org.uk
