Csv2GpsExec -Files convertissor for the GPSexec plugin
  • Csv2GpsExec -Files convertissor for the GPSexec plugin
    Hi all,
    This is my first AutoIt Program .
    Csv2GPSExec.exe is a program who convert speedcams files found on these web sites :
    The output format is compatible with the Guino's plugin GpsExec
    Alertgps.com
    GpsPassion.com
    Trapster.com
    New in V1.7
    SpeeCameraPoi.com
    Download the Csv2GPSExec_V1.7.zip file .
    Follow all instructions for to have a speedcam alert :
    Modify your Exectbl.ini file for your needs .
    You can found the Kuo's exemple here (post #34):
    http://www.mp3car.com/vbulletin/rr-p...-plugin-3.html
    Another exemple (mine) here post# 51):
    http://www.mp3car.com/vbulletin/rr-p...ml#post1290431
    If you like this program just say it me .
    If you know another dowload source for speedcam or poi file I can add a special option for you .
    Thanks again for Guino and Kuo files and help .
    Thanks again to the French AutoIt Forum for this program and his help .
    Nota: If you know another web site where a download is possible I can
    to add a specific option .
    Features:
    V2.1 15/12/2010
    I have adapted the trapster option for the nine possibilities found into the 5 trapster files.
    (Red Light Camera,Fixed Speed Camera,Known Enforcement Point,Combo Camera,Dangerous Intersection,Dangerous Curve,Narrow Bridge Ahead,Toll Booth and School Zone)
    V2.0 07/12/2010
    compatible with the new 5 trapster's files (choose the GARMIN format)
    V1.7 12/05/2009
    Add a New Tab for Speedcamerapoi.com
    Error solved in the Trapster Tab filter (Filter run well now)
    V1.6a 9/05/2009
    Readme.txt file modified
    V1.6 24/04/2009
    Some little modif
    (Kml > Google) is OK now
    V1.5 8/04/2009
    Change conversion Trapster's format
    V1.4 21/02/2009
    I had modified the Google Earth option
    He has a specific tab .
    Modified some cosmetic things .
    V1.3 20/02/2009
    I had modified the Trapster option .
    Now, the Latitude and Longitude are good.
    All necessary files are compacted on csv2gpsexec.exe file.
    Then Google button is OK .
    Add a Readme.txt file ...
    V1.2 18/02/2009
    Add GpsPassion Files ,
    Possibility to create your ExecTbl.ini file,
    Possibility to view of your Poi files in Google Earth,
    Multilanguage, English, French, German and Spanish by default, but you
    can create your own language too .
    V1.1 16/02/2009
    Add Trapster.com files (US Speedcam)
    V1.0 11/02/2009
    Only for GpsAlert files (France , England , Belgium , Nederland , Spain , Portugal , Suedish)
    1
    YES
    100.00%
    1
    NO
    0.00%
    0
    beautiful.. just what i need to convert my trapster stuff.. cant wait to have some free time on my hands
    Live mp3Car Facebook Chat
      The v1.1 run well for Trapster files but i have a little problem for the gpspassion files . If you want to test the v1.1 it is possible .
        If you want to test my v1.2 version and
        give me your opinion.
          i'm trying 1.2 but i dont see any instructions on how to make it work. I go to the trapster page, enter my trapster files and the distance options... then press ok and a message box comes in in french which i believe says its complete... but i dont see a file anywhere. Can you provide instructions?
          NM i see my output files on the desktop.. but its only outputting csv files. I thought the program outputted in a gpsexec compatible format
            Effectively ,I am sorry ,I had not create instructions .
            I create it today .
            So, Each tab is for specific file . For trapster use the trapster tab only .
            When you run the first time csv2gpsexec.exe it unpack 5 .lng files.
            French.lng , English, German,Spanish and defaut.lng .
            So , go on Configuration menu and choose your language .
            On tab trapster:
            Open your .cvs file .
            You can define after , Units, MinHdg,MaxHdg,Distance,"COMMAND" .
            Then push on the OK button .
            The result is one or two files _New.csv but on gpsexec.ini format:
            Latitude,Longitude,MinHdg,MaxHdg,Distance,Units,"B LABLABLA"
            You can two use the "Concatenation" option , then, all files are compiled in one file "Fusion_Radars.cvs" .
            You have one specific tab for ExecTbl.ini exemples file .
            The AlertGps/GpsPassion is on french and the Trapster exemple in english.
            You can use the google button only if a Fusion_radars.csv file exist(See you file on Google Earth).
            Good use ,I add a help file this day
              ok i think i get it now.. i was unaware that the .csv created was what needs to be entered into gpsexec.ini. This is a really helpful utility . Any plans on just outputting the gpsexec.ini file instead of another csv? I know u can open the csv in notepad then copy/paste but it would be handy to just create the file on the fly too.
                The input format is a ascii file Garmin .csv :
                The format must do it this :
                Longitude,Latitude,"XXXXXXXXXXX" .
                Yes, the result file is a gpsexec.ini format only .
                If you know another file format ascii ,I can add it .
                Yes notepad or exel is easy to use but it is so fun to create .
                Thank you for your opinion .
                  v1.3
                  See the first post to dowload the last version.
                  V1.3 :
                  Debug Trapster version
                    I Sonicxtacy,
                    I had modified Csv2Gpsexec on V1.4 version .
                    See the first post and the readme.txt file for all explains .
                      will test after i return from lunch in an hour
                        i created a file using 1.4 and the lat and lon values are reversed in the output file. what am i doing wrong?
                        nm i see the problem i believe. Trapster's .csv files are long,lat,etc,etc. The output file needs to reverse the long and lat
                          As soon as , I modify that in the v1.5 and send it
                          Thanks for this back
                            V1.5 version
                            Hi Sonicxtacy02,
                            You can try this new V1.5 version
                            Thanks for your help
                              i'll try it today and let you know the results!
