Csv2speedzonelimit for the ThunderStick's SpeedZone Plugin
  • Csv2speedzonelimit for the ThunderStick's SpeedZone Plugin
    This software convert csv file on a csv Speedzonelimit file compatible .
    It create:
    - TRAPSTER.csv file .
    The last version is : Csv2Speedzonelimit V1.5
    Historique Version:
    V1.5
    Now, Csv2Speedzonelimit create only a TRAPSTER.csv file compatible with the setup's SpeedzoneLimit
    for different origin POI files.Just put the TRAPSTER.csv on the '\Plugs\SpeedZoneLimit\' and
    run the setup.exe who create itself all files for the SpeedzoneLimit plugin.
    You can to choose the SkinPath in the Speedzone Tab
    Don't use the speedzone setup tab. It is not complet !!!
    V1.4 12/05/2009
    Bad AlertGps's output files solved
    Bad ZLST.TXT output file for Trapster's tab
    New Tab SpeedCameraPoi.com
    V1.3 28/04/2009
    Concatenation is now possible
    ZLST.TXT use the concatenation
    Full Speedzone.ini setup
    V1.2 23/04/2009
    Use the new format of Zones.csv
    Add a Setup Tab for the Speedzone.ini file
    V1.1 04/04/2009
    First Realease
    0
    Yes
    0%
    0
    NO
    0%
    0
    Csv2Speedzonelimit V1.3
    Hi all,
    This is a new version for Csv2Speedzonelimit , the V1.4 .
    Now, the filter for the confidence's level of trapster run well .
    V1.4 As soon as . In test actually
      V1.4 Version
      -These version resolve an error in the output format file
      for the AlertGps files .
      -Add a new SpeedCameraPoi.com Tab
      -In the Speedzone tab, you can to choose now the skinpath
        Update 1.5
        The new version (1.5) create a compatible TRAPSTER.csv file with speedzone's plugin .
        Don't use the speedzone setup tab, it is not complet.
        You must to use the speedzone's setup for to create all files necessaries for speedzone .
        Good use
          ok i got the best CPU usage results while using
          dvbviewer + CoreAVC codec
          CoreAVC is not free though but you can disable deblocking mode and that will get you 25% less CPU usage..
          (i have no issues with MPEG2 channels, but the MPEG4 channels consume 50% of CPU!!!)
