Windows 7 CarPC, Reviewing, testing and breaking!
  • Windows 7 CarPC, Reviewing, testing and breaking!
    Hi guys just building a car pc on an Intel atom dual core board. 1Gb memory, 120GB sata laptop hdd, M4 ATX.
    I though it would be interesting to see how Windows 7 runs and also how good some of the new tweaks and changes work.
    I also thought it would be amusing to try and get it running as a full carpc system and see what does and doesn't work on it. I'm not live in a car at the moment so it is an ideal time to test the theory out
    So I am listing up what works and doesn't and will do some benchmarks for speed tests.
    Anything you want testing shout up with a link and I'll try and get it running
    Working 100%
    Windows
    Installed Win 7 Ultimate N X86 RC0. no IE etc.
    Windows Boots. need to time hibernate and standby, cold boot.
    All devices detected in device manager.
    nice and snappy not as much "vista lag"
    Nice advanced power options
    soundcard is HD audio
    GFX detected correctly
    Showing as 4 core 1.60GHz system
    Ride runner installs 100% with no errors
    Winamp 5.13 installs and plays audio 100%
    RRconfig triggers UAC and loads.
    Under investigation
    Sound card issues with onboard sound.
    RideRunner is alive and kicking with sound through RDP, had to install windows and IE versions of flash. Now testing that.
    Kind of works
    Works with tweaks
    Works in Windows XP mode
    Doesn't work at all, even a little bit
    Speedtests
    Graphics
    CPU
    Memory
    I will keep this top post updated as I go through the tests.
    Mileage Calculator and logger in progress check it out :)
    http://img.photobucket.com/albums/v4...italcarsig.jpg
    I'm not live in a car at the moment so it is an ideal time to test the theory out?
    huh?
    and yeah I agree win 7 ftw its been built around touch screens, been using if since it first hit bit (january was it?), zero complaints boots faster that my xp partition..
      huh?
      I am running it on a test bench at the moment to see what does and doesn't work, then once/if I have it something like I will put it in the car and test it on the move.
      There are a lot of touch enhancements so will see what they do for the usability
        testing it with what? I've found it will support pretty much everything that i've thrown at it, as long as its Vista compatible Except Deamon tools =/ but I believe there coming out with a win 7 version for it soon if its not already out
          When I tried it, in installed my onboard Realtek as 'HD Audio' as well, except it's 2-channel, with a mic and digital 'in', and that's it! I couldn't get the OEM drivers to work...
          So I scrapped the W7 install.
            So did you not get any sound at all from it?
              What build did you use? that could be your problem.. once you get above 7077 a lot of issues like that started popping up
                So have you run carpc software on it or used it as a normal OS?
                  So far just a normal os, so no I haven't run any frontends on it, as I said you should be testing 7077 and no other build
                    I am testing the release candidate as that is the current version and nearer to market.
                      Which is 7077? lol cuz thats what version will be for released at the end of this year
                      Edit: See my confusion nearest to the market and current version are two way different builds
                      And will run very differently
                        No this is Build 7100 MSDN version.
                          lol yeah I would switch over to 7077 as thats the build there shipping out for retail the 7100's are test versions that there messing around with ie. there not a very stable version. Sorry not tryn to rain on your party or anything but that would suck if you did a bunch of testing on a non-retail/test build
                            I see where you are coming from now, as I understand it the other version is the main release candidate and the one I have is the MSDN test version that gets more updates and test code there are rumours of a nightly/weekly build also, this is then incorporated into the final release to retail.
                            So it should be a more up to date version meaning issues that are there may be resolved and I will get those updates before the "normal" version.
                              http://www.win7connect.com/news/wind...explained.html
                              here this will help clarify, idk I personally would stick with the 7077 but its all good hey why not test both? ayy?
